EDIT: My solution was to just drop openSUSE and switch to Debian where it works fine.
I have tried on both openSUSE Leap and Rocky Linux, with both docker and podman, and nothing has worked.
I download the docker-compose.yml file, I change the data directory to a mount for another drive, I change timezone, email, admin password, hostname, and nothing else.
However, upon running docker compose up -d I go to the port for the seafile and I get http 502.
docker compose logs -f shows the following:
seafile |
seafile | verifying password of user seafile ...
seafile | Failed to connect to mysql server using user "seafile" and password "***": Access denied for user 'seafile'@'172.28.0.4' (using password: YES)
seafile |
seafile | [2023-06-04 19:52:53] Now running setup-seafile-mysql.py in auto mode.
seafile | File "/scripts/start.py", line 95, in <module>
seafile | main()
seafile | File "/scripts/start.py", line 59, in main
seafile | init_seafile_server()
seafile | File "/scripts/bootstrap.py", line 158, in init_seafile_server
seafile | call('{} auto -n seafile'.format(setup_script), env=env)
seafile | File "/scripts/utils.py", line 70, in call
seafile | return subprocess.check_call(*a, **kw)
seafile | File "/usr/lib/python3.8/subprocess.py", line 364, in check_call
seafile | raise CalledProcessError(retcode, cmd)
seafile | subprocess.CalledProcessError: Command '/opt/seafile/seafile-server-10.0.1/setup-seafile-mysql.sh auto -n seafile' returned non-zero exit status 255.```
