6.2.X redirect on alternate port; Solution included; Manual needs update
I’ve linked a previous post with details of the problem at the bottom of this post. The Seafile manual needs to be updated with the following solution.
Summary of issue:
Since the release of 6.2.X, the WebUI redirects (to port 80) when using an alternate port number in NGinx.
Solution:
In the Nginx config file for the site, the solution is to replace this line:
proxy_set_header Host $host;
with this line:
Requesting that the manual be updated with this information.
You can change it yourself and open a pull request on GitHub.
Ah… Cool… I did not know that. :slight_smile: Will take care of it later today. Can you provide the link to the github?
Ok, I found Seafile on github. Do I just need to issue a pull request with my proposed changes to the manual, or is there something else I need to do?
You got it, it is quite easy.
