After redeploy portainer seafile server not reachable
Hi, maybe you can help me here.
I thought it gets time to redeploy the containers in portainer and doing that with recreate using repull image what usually take latest image.
Now all containers are on “green” but I cannot reach seafile.
When using as usual locally local_IP:8099 I am getting “502 bad gateway” and also on android app I cannot reach it anymore.
What could cause that trouble?
In seafile log I see some errors with 12.0.11 and when checking the latest available version it says 12.0.14 and I thought this will be taken when redeploying latest???
*** Booting runit daemon...
*** Runit started as PID 21
2025-07-06 15:46:38 Nginx ready
2025-07-06 15:46:38 This is an idle script (infinite loop) to keep container running.
[2025-07-06 15:46:38] Skip running setup-seafile-mysql.py because there is existing seafile-data folder.
[07/06/2025 15:46:38][upgrade]: The container was recreated, start fix the media symlinks
mv: cannot stat '/opt/seafile/seafile-server-12.0.11/seahub/media/avatars/*': No such file or directory
ln: failed to create symbolic link '/opt/seafile/seafile-server-12.0.11/seahub/media/avatars': No such file or directory
  File "/scripts/start.py", line 94, in <module>
    main()
  File "/scripts/start.py", line 61, in main
    check_upgrade()
  File "/scripts/upgrade.py", line 120, in check_upgrade
    fix_media_symlinks()
  File "/scripts/upgrade.py", line 106, in fix_media_symlinks
    call('ln -sf %s %s' % (dst_avatars_dir, avatars_dir))
  File "/scripts/utils.py", line 70, in call
  File "/usr/lib/python3.12/subprocess.py", line 413, in check_call
subprocess.CalledProcessError: Command 'ln -sf /shared/seafile/seahub-data/avatars /opt/seafile/seafile-server-12.0.11/seahub/media/avatars' returned non-zero exit status 1.
Anyone?
I am still on 12.0.11 and fail updating via portainer.
I just stopped and redeployed but as written above - not working like that.
What is the correct procedure to update to 12.0.14, or latest?
Did the same via portainer and the update to 12.0.14 was successfull.
Can you please explain how you performed the update, I mean what steps did you use? I just stopped the container and redeployed but I couldn’t reach the local_IP:8099
I don’understand what’s wrong
Sorry, I did the same and it works easily.
