I’m trying to install seafile 7.1.5 on a Debian 10 vps which has php-fpm on port 8000.
So I edited /conf/gunicorn.conf.py to bind to 127.0.0.1:8085
When I ./seafile.sh start, that started seaf-server process and opened port 8082.
When I ./seahub.sh start 8085, it started 5/6 Python processes listeining on por t8085.
But it didn’t open port 8085 like .seafile.sh start opened port 8082.
I’m a newbie to firewall. And it was suggested to get port 8085 open. But I can’t get nftables to open port 8085.
Was ./seahub.sh start 8085 supposed to open port 8085 without me doing anything?
Port 8082 seems to be open, but does this mean I still have to add a firewall rule for it?
I’m making some progress on this seafile 7.1.5 install on Debian 10 vps which has php-fpm listening on port 8000.
I decided to move php7.3-fpm to /var/run/php7.3-fpm.sock and that seemed to free up port 8000.
A key change, I think, that opened port 8000 with the ./seahub.sh start command with changing gunicorn.conf.py from
bind = " 127.0.0.1:8000"
to
bind = "0.0.0.0:8000"
The active ethernet was enp3s0, so maybe that’s why the change from 127.0.0.1 to 0.0.0.0 was needed?
Anyways, now I have a seahub signin screen when I go to http://krishnify.com:8000 Yay!
http://krishnify.com:8082 doesn’t give a promising result. It just gives a blank screen.
But at least I have part of seafile working.
Maybe it’s now dealing with the Nginx conf. Which I’m a newbie at also.
Being a vps system admin newbie, I wonder if anyone might have any input on the following questions I have:
0. Currently I have SERVER_ROOT commented out in seahub_settings.py
If I try to set it to seafile.krishnify.com/seafhttp, seahub won’t start. Seahub starts without SERVER_ROOT right now.
Do I need to create a CNAME DNS entry for the SERVER_ROOT?
Currently, I do have a CNAME DNS entry for seafile.krishnify.com.
However, probably due my lack of Nginx config knowledge, seafile.krishnify.com goes to another website on the vps, instead of correctly proxy_passing to seafile.krishnify.com
What’s wrong with my Nginx config?
listen 80;
listen [::]:80;
server_name seafile.krishnify.com;
autoindex off;
client_max_body_size 100M;
access_log /etc/nginx/seafile.com.access.log;
error_log /etc/nginx/seafile.com.error.log;
proxy_pass http://localhost:8000;
proxy_set_header Host $host;
proxy_read_timeout 1200s;
location ^~ /seafhttp {
proxy_pass http://localhost:8082;
proxy_connect_timeout 36000s;
proxy_read_timeout 36000s;
proxy_send_timeout 36000s;
root /home/seafileu/seafile-server/seahub;
Any tips and suggestions would be appreciated.
