Android 2.2.32 camera upload failed
@daniel.pan You mentioned before that my problem is not the same as the SQL Android 9 problem, and that makes total sense. But whatever you just changed in 2.2.39 seems to have fixed things on my end as well though! :open_mouth:
I just upgraded, disabled and re-enabled camera uploads, and now it’s catching up on pictures from the past few months! :smiley:
Hopefully it’s fixed for the others too!
Side question which I asked in another topic but never got a reply to: should I be running the version from f-droid or from the google play store? The play store version seems to be lagging behind quite often.
Yep I am back in action with 2.2.39!
Glad to hear the problem is solved.
We will update google play store soon. f-droid is not maintained by us yet.
Still does not work for me.
@daniel.ke Does it say 2.2.39 under settings for you and did you disable and re-enable camera uploads? Can you then perhaps post your logs so @daniel.pan can have a look at them? That way we can all try to help investigate this issue further.
now it works for me too.
too soon. Already nothing uploads. After 2.2 GB was the end
I had to manually trigger the sync again in Android via accounts but now everything works. All videos have been uploaded as well. Thank you!
Nope, as mentioned in /seadroid/issues/883 , still not working. Downgrading again does the trick.
@Marco_Behler could you please be more specific about the version you’re using. The issue was fixed in 2.2.39 which may not be the version you’re using.
same issue with 2.2.32 (play store), after ugrading to 2.2.39 via apk it seems to work now. thanks!
Not uploading to me. Android 11 and 2.2.39 version.
Reinstalled two days ago. Lots of new pictures and videos.
Upload is not working properly for me either. I suspect it could be related to google photos app showing two ‘Camera’ folders. One on the phone, one one the SD card. Looks like Seafile never uploads anything from the SD card. The SD Card folder cannot be explicitly selected in the upload setup wizard as it only shows the one from the phone memory.
Why are the ‘imagebuckets’ filtered for duplicates based on the name for Android 10 and above? I suspect this could be the reason the upload won’t work for me.
GalleryBucketUtils.java - Lines 290-297 in getImageBuckets()
