I am able to upload from my Desktop client just fine and not seeing any other issues. Just when I try to upload from my Android device it is failing. Tried setting up the Camera Folder Upload and also tested with manually uploading 1 picture. Both fail from the mobile client.
When checking seahub logs Im seeing alot of “django.request:152 get_response Not Found: /upload-api/0ce9e9dc-63bf-494c-be15-27c5644aa455”
The Seahub.error.log is showing quite a bit of “failed (104: Connection reset by peer) while reading upstream” as well as “failed (111: Connection refused) while connecting to upstream”
Not sure where else to look for what is causing my issue. I do have my nginx container separate from the seafile container. Though if it was a larger issue I would expect my Desktop to also have issues and not just my Android.
