Android Client very slow / don't work
hi!
the android client 3.0.18 is very slow. if i connect the server, i must wait more than 5 minutes if the connection etablished. file upload or download is not possibile, the “waiting wheel” rotates infinity. i’ve tested that with 3 different android mobile devices - wlan or mobile data does not matter. server version is 13.0.12 (docker) but also don’t work with 12.x version.
any hint?
Mario
That version is working fine for me. It might help to try from a browser on your phone. Log in seafile website, upload, and download some files and see if it’s also slow.
you are a lucky guy. web upload with tested mobile phones is very fast. but the client dont work… i found an old galaxy s10 and try it out - but same issue. server connect take along 10 minutes, download or upload is not possible.
Are there any errors in the server’s logs while that connection is happening?
I wish I could give some useful advice, but I can’t think of any reason that it would take that long without just failing completely.
i’ve checked all logfiles @ /opt/seafile-data/seafile/logs but no suspicions entrys. the only entry is :
/opt/seafile/seafile-server-13.0.12/seahub/thirdpart/django/db/backends/utils.py:98: RuntimeWarning: Accessing the database during app initialization is discouraged. To fix this warning, avoid executing queries in AppConfig.ready() or when your app modules are imported.
warnings.warn(self.APPS_NOT_READY_WARNING_MSG, category=RuntimeWarning)
and a info like this:
[2025-11-17 09:46:14] [INFO] Set language code to en for user: mario@abc.de
so i try to set the phone language from german to english, but without succes. the login procedure takes over 10 minutes and open a libary takes 10 minutes, too.
Have you enabled memcached or redis?
yes sir!
CACHE_PROVIDER=redis
REDIS_HOST=redis
REDIS_PORT=6379
REDIS_PASSWORD=
but in seafile 12 i used memcache, the same effect.
I Try to comment reddis out, but without any effect
If you use Seafile web interface with a desktop browser, is it also very slow?
No. Desktop Client, Desktop Browser and IOS App works fine. The Mobile Browser works also fine. WLAN or mobile data does not matter.
I have no idea why the Android client is slow in your case.
You might consider registering an account at plus.seafile.com and testing again, as this could help you identify a possible reason.
after a many many many hours of research, now i found the problem. i use shorewall firewall, this was the problem. i disabled it, an the android client works very fast. i never pay attention of this, because all other clients, like windows, linux or ios works fine. i created some special shorewall rules and now, all is fine :slight_smile:
