Dear Forum-Member,
I feel bad and ashame for having to ask you guys again about a Nginx problem of mine. I have been struggeling with this a while now and decided to ask you, since alot of you seem to understand Nginx quite well.
Basicly I’m building a new Server based on an running server just with different URL-Name. only difference is that I didn’t install certbot with nginx plugin. Rather I installed Nginx as guided from the official website. Then installed certbot without plugins and used the standalone Parameter to fetch the certificates. That all worked quite fine.
The Error Message is:
nginx: [emerg] unexpected "m" in /etc/nginx/conf.d/seafile.conf:24
I installed Nginx like this:
sudo apt-get install nginx
My Nginx is has the following Details:
nginx version: nginx/1.14.0
built by gcc 7.3.0 (Ubuntu 7.3.0-16ubuntu3)
built with OpenSSL 1.1.0g 2 Nov 2017
TLS SNI support enabled
configure arguments:
–prefix=/etc/nginx
–sbin-path=/usr/sbin/nginx
–modules-path=/usr/lib/nginx/modules
–conf-path=/etc/nginx/nginx.conf
–error-log-path=/var/log/nginx/error.log
–http-log-path=/var/log/nginx/access.log
–pid-path=/var/run/nginx.pid
–lock-path=/var/run/nginx.lock
–http-client-body-temp-path=/var/cache/nginx/client_temp
–http-proxy-temp-path=/var/cache/nginx/proxy_temp
–http-fastcgi-temp-path=/var/cache/nginx/fastcgi_temp
–http-uwsgi-temp-path=/var/cache/nginx/uwsgi_temp
–http-scgi-temp-path=/var/cache/nginx/scgi_temp
–user=nginx
–group=nginx
–with-compat
–with-file-aio
–with-threads
–with-http_addition_module
–with-http_auth_request_module
–with-http_dav_module
–with-http_flv_module
–with-http_gunzip_module
–with-http_gzip_static_module
–with-http_mp4_module
–with-http_random_index_module
–with-http_realip_module
–with-http_secure_link_module
–with-http_slice_module
–with-http_ssl_module
–with-http_stub_status_module
–with-http_sub_module
–with-http_v2_module
–with-mail
–with-mail_ssl_module
–with-stream
–with-stream_realip_module
–with-stream_ssl_module
–with-stream_ssl_preread_module
–with-cc-opt=’-g -O2 -fdebug-prefix-map=/data/builder/debuild/nginx-1.14.0/debian/debuild-base/nginx-1.14.0=. -specs=/usr/share/dpkg/no-pie-compile.specs -fstack-protector-strong -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fPIC’
–with-ld-opt=’-Wl,-Bsymbolic-functions -specs=/usr/share/dpkg/no-pie-link.specs -Wl,-z,relro -Wl,-z,now -Wl,–as-needed -pie’
My Nginx config looks like this:
user nginx;
worker_processes 1;
error_log /var/log/nginx/error.log warn;
pid /var/run/nginx.pid;
events {
worker_connections 1024;
http {
log_format main '$remote_addr - $remote_user [$time_local] "$request" '
'$status $body_bytes_sent "$http_referer" '
'"$http_user_agent" "$http_x_forwarded_for"';
access_log /var/log/nginx/access.log main;
sendfile on;
#tcp_nopush on;
keepalive_timeout 65;
#gzip on;
include /etc/nginx/conf.d/*.conf;
And most important my Seafile.conf for Nginx saved at: /etc/nginx.conf.d/
line 24 is the line where i have add_header Strict-Transport-Security
listen 80;
listen [::]:80;
server_name host.domain.tld;
return 301 https://$server_name$request_uri;
listen 443 ssl http2;
listen [::]:443 ssl http2;
ssl_certificate /etc/letsencrypt/live/host.domain.tld/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/host.domain.tld/privkey.pem; # managed by Certbot
#include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
#ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
ssl_protocols TLSv1.2;
#From Cisco:
ssl_ciphers "ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-R$
#From Hebers:
#ssl_ciphers ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-SHA;
ssl_prefer_server_ciphers on;
ssl_session_timeout 5m;
ssl_dhparam /etc/nginx/dhparam.pem;
# Enables or disables emtting nginx version on error pages in the "Server" response header
server_tokens off;
proxy_set_header Host $host;
proxy_read_timeout 1200s;
proxy_request_buffering off;
proxy_connect_timeout 36000s;
proxy_read_timeout 36000s;
proxy_send_timeout 36000s;
root /home/myname/seafile/seafile-server-latest/seahub;
Any Help really appreciated !
with kind Regards,
Michael
I forget about semicolon so often, it was the first thing I checked.
