leon
March 3, 2020, 5:26am
I deployed seafile CE with docker. The corresponding seafile version inside the docker image is shown as Server Version: 7.0.5. The ports are both 80 and 443. The avatar loading always shows incorrect url as http://file.xxx.com:8000/media/avatars. The screenshot is shown as follow:
My seafile service url is set as:
SERVICE_URL: https://file.xxx.com
FILE_SERVER_ROOT: https://file.xxx.com/seafhttp
where xxx.com corresponds to our company domain name.
The configuration of nginx within docker image is by default. Does anyone suggest how to resolve this issue?
RTD
April 13, 2020, 11:29am
Hi, I have the same issue.
I have tried to follow this
but it doesn’t work with my setup. I have a Synology.
11114
October 15, 2020, 5:23am
3
I found a solution, and it helps, but it is in Chinese.
https:// bbs.seafile. com/t/topic/11537
(sorry for I can;t include url.)
In summary, you should delete tmp/seahub_cache, and the seafile will renew and apply your settings.(in my comprehension.)
However, I deployed seafile with docker, and there is not a tmp/seahub_cache, but I restart the memcached, and it works.
docker restart seafile-memcached
like above.
