Hi!
I’ve been troubleshooting this for hours now and can’t figure out why this isn’t working with wasabi s3 backend. The same config works just fine with AWS S3
I have the following three buckets in wasabi in the region eu-central-1 (note, at wasabi this is in Amsterdam, not Frankfurt):
- xie8do-commit-objects
- xie8do-fs-objects
- xie8do-block-objects
I want to use AWS signature version 4, but when setting this
[commit_object_backend]
name= s3
bucket = xie8do-commit-objects
key_id = my-key-id
key = my-secret-key
host = s3.eu-central-1.wasabisys.com
use_v4_signature = true
aws_region = eu-central-1
path_style_request = true
memcached_options = --SERVER=memcached --POOL-MIN=10 --POOL-MAX=100
use_https = true
[fs_object_backend]
same as above except fs bucket name
[block_backend]
same as above except block bucket name
And also do in ~/.boto
[s3]
use-sigv4 = True
the log shows
<Error><Code>SignatureDoesNotMatch</Code><Message>The request signature we calculated does not match the signature you provided. Check your key and signing method.</Message><AWSAccessKeyId>JAHDSALGFLJAREDACTED</AWSAccessKeyId><StringToSign>AWS4-HMAC-SHA256
20200212/eu-central-1/s3/aws4_request
45d0ec0b950c9ac55a8b42369a44dcef392ba18ea56da56923ece407a5a96c76</StringToSign><SignatureProvided>b8a516cb34937033ce224e7a32e51c12ab7f823baba9f52f2174940dd5ef53fd</SignatureProvided><StringToSignBytes>41 57 53 34 2d 48 4d 41 43 2d 53 48 41 32 35 36 a a 32 30 32 30 30 32 31 32 2f 65 75 2d 63 65 6e 74 72 61 6c 2d 31 2f 73 33 2f 61 77 73 34 5f 72 65 71 75 65 73 74 a 34 35 64 30 65 63 30 62 39 35 30 63 39 61 63 35 35 61 38 62 34 32 33 36 39 61 34 34 64 63 65 66 33 39 32 62 61 31 38 65 61 35 36 64 61 35 36 39 32 33 65 63 65 34 30 37 61 35 61 39 36 63 37 36</StringToSignBytes><CanonicalRequest>PUT
/034b94fb-2fb6-4bbc-b86d-590d8b9e0786/1160a2cfa2bfad637db0e26a9ed718828e016fdc
host:xie8do-commit-objects.s3.eu-central-1.wasabisys.com
x-amz-content-sha256:1d5e9fe4dad7f0d131574e979eca1472e215aa43795f0ece39ab72edab57128f
host;x-amz-content-sha256
1d5e9fe4dad7f0d131574e979eca1472e215aa43795f0ece39ab72edab57128f</CanonicalRequest><CanonicalRequestBytes>50 55 54 a 2f 30 33 34 62 39 34 66 62 2d 32 66 62 36 2d 34 62 62 63 2d 62 38 36 64 2d 35 39 30 64 38 62 39 65 30 37 38 36 2f 31 31 36 30 61 32 63 66 61 32 62 66 61 64 36 33 37 64 62 30 65 32 36 61 39 65 64 37 31 38 38 32 38 65 30 31 36 66 64 63 a a 68 6f 73 74 3a 63 68 6f 6f 34 69 78 6f 6f 39 6f 6f 2d 63 6f 6d 6d 69 74 2d 6f 62 6a 65 63 74 73 2e 73 33 2e 65 75 2d 63 65 6e 74 72 61 6c 2d 31 2e 77 61 73 61 62 69 73 79 73 2e 63 6f 6d a 78 2d 61 6d 7a 2d 63 6f 6e 74 65 6e 74 2d 73 68 61 32 35 36 3a 31 64 35 65 39 66 65 34 64 61 64 37 66 30 64 31 33 31 35 37 34 65 39 37 39 65 63 61 31 34 37 32 65 32 31 35 61 61 34 33 37 39 35 66 30 65 63 65 33 39 61 62 37 32 65 64 61 62 35 37 31 32 38 66 a a 68 6f 73 74 3b 78 2d 61 6d 7a 2d 63 6f 6e 74 65 6e 74 2d 73 68 61 32 35 36 a 31 64 35 65 39 66 65 34 64 61 64 37 66 30 64 31 33 31 35 37 34 65 39 37 39 65 63 61 31 34 37 32 65 32 31 35 61 61 34 33 37 39 35 66 30 65 63 65 33 39 61 62 37 32 65 64 61 62 35 37 31 32 38 66</CanonicalRequestBytes><RequestId>5D92B42A52124773</RequestId><HostId>nmG9t6bD75KoJSb2Ddkum01+O/F0v/TXznfkXaQwU28L64roIfLHCgKNdLsuUiXhK9zVAJEIqVXY</HostId></Error>
If I change in seafile.conf
use_v4_signature = false
and in ~/.boto
[s3]
use-sigv4 = False
it works fine.
taking out path_style_request = true did not make a difference.
I could successfully put files into the buckets using v4 signatures by following instructions found in the wasabi knowledge base. I would post the link to that article, but it looks like I can’t. Just google/duckduckgo How do I use AWS Signature Version 4 with Wasabi? and you’ll find it.
So from wasabi’s side this should work.
I’m wondering where and how does the v4 signature get calculated in seafile pro? is it possible that seafile is getting confused with the wasabi region eu-central-1 not being the same as eu-central-1 in AWS? Is it possible that seafile is calculating the signature based on the wrong region?
I tried taking out aws_region from seafile.conf but then seafile server can’t be started.
Any help would be appreciated!
edit:
Fresh/New setup of Seafile Pro 7.0.13
