Hello I follow the flow to build the seafile server from the github(/haiwen/seafile-rpi) repository.(I am not sure if i was need to try with docker).
I have the following tree. Whats next how to start the server and access it from my internal network where are the configurations.Do I need to compile seafile-server I see there is also docker compose file can i host in on docker.I am lost.Thank you for the help.
├── build.sh
├── build-server.py.patch
├── built-seafile-server-pkgs
│ └── seafile-server-9.0.9-focal-armv7l.tar.gz
├── built-seafile-sources
│ └── R9.0.9
├── go
│ └── pkg
├── haiwen-build
│ ├── libevhtp
│ ├── libsearpc
│ ├── seafdav
│ ├── seafile-server
│ ├── seafobj
│ ├── seahub
│ └── seahub_thirdparty
└── opt
└── local
