I’m trying to build Seafile (server and hub) from source on Gentoo. I believe I have nearly all dependencies; I’m expecting to see obvious compile errors for any that I missed.
I’ve gotten these tarballs:
ccnet-server-v6.2.0-server.tar.gz
libevhtp-1.2.12-1.tar.gz
libsearpc-v3.1-latest.tar.gz
seafile-server-v6.2.0-server.tar.gz
seahub-v6.2.0-server.tar.gz
I am attempting to install into ~/usr/local (under the user’s home dir) by way of --prefix on the ./configure commands. I am following the instructions at https://manual.seafile.com/build_seafile/server.html . libevhtp and libsearpc seem to have built and installed without issue. Next is ccnet-server but I am not succeeding.
I have set these environment variables to try to help the build:
CPATH=/home/seafile6/seafile-server/src/libsearpc-3.1-latest/test
PKG_CONFIG_PATH=/home/seafile6/usr/local/lib/pkgconfig
LD_RUN_PATH=/home/seafile6/usr/local/lib
I set the CPATH because without it, the ccnet build fails at:
../common/rpc-service.c:40:30: fatal error: searpc-signature.h: No such file or directory #include "searpc-signature.h"
Once I set the CPATH, then the build fails at:
[...lots more output above this...]
/bin/sh ../../libtool --tag=CC --mode=link gcc -g -O2 -no-undefined -o ccnet-server ccnet-server.o server-session.o user-mgr.o group-mgr.o org-mgr.o ../common/ccnet-db.o .
./common/session.o ../common/peer-mgr.o ../common/packet-io.o ../common/message.o ../common/perm-mgr.o ../common/log.o ../common/peer.o ../common/algorithms.o ../common/handsha
ke.o ../common/processor.o ../common/getgateway.o ../common/connect-mgr.o ../common/message-manager.o ../common/proc-factory.o ../common/ccnet-config.o ../common/rpc-service.o
../common/peermgr-message.o ../common/processors/sendmsg-proc.o ../common/processors/rcvmsg-proc.o ../common/processors/rcvcmd-proc.o ../common/processors/putpubinfo-proc.o ../
common/processors/getpubinfo-proc.o ../common/processors/keepalive2-proc.o ../common/processors/mqserver-proc.o ../common/processors/service-proxy-proc.o ../common/processors/s
ervice-stub-proc.o ../common/processors/rpcserver-proc.o ../common/processors/threaded-rpcserver-proc.o ../common/processors/echo-proc.o ../common/processors/sendsessionkey-pro
c.o ../common/processors/recvsessionkey-proc.o ../common/processors/sendsessionkey-v2-proc.o ../common/processors/recvsessionkey-v2-proc.o -levent ../../lib/libccnetd.la ../..
/net/common/db-wrapper/libdbwrapper.la -lglib-2.0 -lgobject-2.0 -lglib-2.0 -lssl -lcrypto -luuid -lsqlite3 -lpthread -L/home/seafile6/usr/local/lib -lsearpc -lgio-2.0 -lgob
ject-2.0 -lglib-2.0 -ljansson -L/usr/lib64 -lmysqlclient -lpthread -lz -lm -lssl -lcrypto -ldl -L/usr/lib64/postgresql-9.5/lib64 -lpq
libtool: link: gcc -g -O2 -o ccnet-server ccnet-server.o server-session.o user-mgr.o group-mgr.o org-mgr.o ../common/ccnet-db.o ../common/session.o ../common/peer-mgr.o ../comm
on/packet-io.o ../common/message.o ../common/perm-mgr.o ../common/log.o ../common/peer.o ../common/algorithms.o ../common/handshake.o ../common/processor.o ../common/getgateway
.o ../common/connect-mgr.o ../common/message-manager.o ../common/proc-factory.o ../common/ccnet-config.o ../common/rpc-service.o ../common/peermgr-message.o ../common/processor
s/sendmsg-proc.o ../common/processors/rcvmsg-proc.o ../common/processors/rcvcmd-proc.o ../common/processors/putpubinfo-proc.o ../common/processors/getpubinfo-proc.o ../common/p
rocessors/keepalive2-proc.o ../common/processors/mqserver-proc.o ../common/processors/service-proxy-proc.o ../common/processors/service-stub-proc.o ../common/processors/rpcserv
er-proc.o ../common/processors/threaded-rpcserver-proc.o ../common/processors/echo-proc.o ../common/processors/sendsessionkey-proc.o ../common/processors/recvsessionkey-proc.o
../common/processors/sendsessionkey-v2-proc.o ../common/processors/recvsessionkey-v2-proc.o ../../lib/.libs/libccnetd.a -levent -L/home/seafile6/usr/local/lib ../../net/common
/db-wrapper/.libs/libdbwrapper.a -L/usr/lib64 -L/usr/lib64/postgresql-9.5/lib64 -luuid -lsqlite3 /home/seafile6/usr/local/lib/libsearpc.so -lgio-2.0 -lgobject-2.0 -lglib-2.0 /u
sr/lib64/libjansson.so -lmysqlclient -lpthread -lz -lm -lssl -lcrypto -ldl -lpq -Wl,-rpath -Wl,/home/seafile6/usr/local/lib -Wl,-rpath -Wl,/home/seafile6/usr/local/lib
../common/rpc-service.o: In function `ccnet_start_rpc':
/home/seafile6/seafile-server/src/ccnet-server-6.2.0-server/net/server/../common/rpc-service.c:63: undefined reference to `searpc_signature_string__void'
/home/seafile6/seafile-server/src/ccnet-server-6.2.0-server/net/server/../common/rpc-service.c:68: undefined reference to `searpc_signature_objlist__void'
[...and many more similar "searpc_signature_****" lines below here...]
~/usr/local has the following stuff in it:
├── bin
│ └── searpc-codegen.py
├── include
│ ├── ccnet
│ │ ├── async-rpc-proc.h
│ │ ├── ccnet-client.h
│ │ ├── ccnet-object.h
│ │ ├── ccnetrpc-transport.h
│ │ ├── ccnet-session-base.h
│ │ ├── cevent.h
│ │ ├── invoke-service-proc.h
│ │ ├── job-mgr.h
│ │ ├── message.h
│ │ ├── mqclient-proc.h
│ │ ├── option.h
│ │ ├── packet.h
│ │ ├── peer.h
│ │ ├── processor.h
│ │ ├── proc-factory.h
│ │ ├── rpcserver-proc.h
│ │ ├── sendcmd-proc.h
│ │ ├── status-code.h
│ │ ├── threaded-rpcserver-proc.h
│ │ ├── timer.h
│ │ └── valid-check.h
│ ├── ccnet.h
│ ├── evhtp
│ │ ├── config.h
│ │ ├── evhtp.h
│ │ ├── parser.h
│ │ └── thread.h
│ ├── evhtp.h
│ ├── searpc-client.h
│ ├── searpc.h
│ ├── searpc-named-pipe-transport.h
│ ├── searpc-server.h
│ └── searpc-utils.h
├── lib
│ ├── libccnet.a
│ ├── libccnet.la
│ ├── libccnet.so -> libccnet.so.0.0.0
│ ├── libccnet.so.0 -> libccnet.so.0.0.0
│ ├── libccnet.so.0.0.0
│ ├── libevhtp.a
│ ├── libsearpc.a
│ ├── libsearpc.la
│ ├── libsearpc.so -> libsearpc.so.1.0.2
│ ├── libsearpc.so.1 -> libsearpc.so.1.0.2
│ ├── libsearpc.so.1.0.2
│ └── pkgconfig
│ ├── evhtp.pc
│ └── libsearpc.pc
└── lib64
└── python2.7
└── site-packages
└── pysearpc
├── client.py
├── client.pyc
├── client.pyo
├── common.py
├── common.pyc
├── common.pyo
├── __init__.py
├── __init__.pyc
├── __init__.pyo
├── server.py
├── server.pyc
└── server.pyo
