Hello all!
I am looking for help regarding initial setup. On my fresh instance, Seadoc and related features are not working. Wiki features do not work, and I am unable to create/edit .sdoc files.
My configuration is relatively simple, and close to the stock setup. I am using the latest Seafile 13 community edition Docker setup instructions. I consolidated the compose files into a single compose file, and deployed using Portainer’s stack feature. Because I have multiple stacks/containers running on one server IP, I use Nginx Proxy Manager (NPM) to terminate SSL and handle all incoming connections on one port.
Because of this, I had to make adjustments to the compose file to account for a reverse proxy handling SSL. I have caddy container attached to a second network, so that NPM can reach it. In several places, I had to customize the XXX_PROTOCOL or other service URLs to be http or https , depending on whether the URL was internal or external. All of the caddy labels use http because they are internal traffic. And in the seahub_settings.py, I added CSRF_TRUSTED_ORIGINS = [“https://seafile.example.com”] . These steps fixed the issue of not being able to proceed after initial login (403).
I am able to access https://seafile.example.com/sdoc-server/ and I see a page with: Welcome to sdoc-server. The current version is 2.0.9.
The symptom I see is when opening an sdoc file, the request for the document (ex, https://seafile.example.com/sdoc-server/api/v1/docs/bd262c77-0e5c-4f30-895f-4c8ef22bbae3/ hangs and eventually terminates. A similar problem happens when I try to create a page in a Wiki.
The error in sdoc-server.log that appears once the request terminates is
[2026-03-27 16:30:25] [ERROR] index.js[177] - Service unknown error
[2026-03-27 16:30:25] [ERROR] index.js[178] - error_type: UNKNOWN_ERROR
[2026-03-27 16:30:25] [ERROR] index.js[179] - error_message: timeout of 60000ms exceeded
[2026-03-27 16:30:25] [ERROR] index.js[180] - error_stack: AxiosError: timeout of 60000ms exceeded
at RedirectableRequest.handleRequestTimeout (/opt/sdoc-server/sdoc-server-2.0.9/sdoc-server/node_modules/axios/dist/node/axios.cjs:3365:16)
at RedirectableRequest.emit (node:events:524:28)
at Timeout.<anonymous> (/opt/sdoc-server/sdoc-server-2.0.9/sdoc-server/node_modules/follow-redirects/index.js:210:12)
at listOnTimeout (node:internal/timers:581:17)
at process.processTimers (node:internal/timers:519:7)
at Axios.request (/opt/sdoc-server/sdoc-server-2.0.9/sdoc-server/node_modules/axios/dist/node/axios.cjs:4483:41)
[2026-03-27 16:30:25] [ERROR] document-controller.js[56] - Get doc download link error
[2026-03-27 16:30:25] [ERROR] document-controller.js[64] - Get doc download link error. request url is: https://seafile.example.com/api/v2.1/seadoc/download-link/bd262c77-0e5c-4f30-895f-4c8ef22bbae3/
I cannot find any cross-correlating log in seafile-data/seafile/logs.
I tried:
- Setting
SEAFILE_SERVICE_URLfromhttp://seafiletohttps://seafile.example.comfrom this post: "Load doc content error" - #18 by hayato
I have not tried:
- Editing the NGINX inside seafile from this post: "Load doc content error" - #7 by TechnicallyReal
- I do not want to be tinkering with an auto generated NGINX file. That just sounds like a recipe for a fragile build that I have to redo every time the container is restarted.
- Setting up SeaDoc as a standalone service
- I do not believe this would fix the issue because I have proven I can access the SeaDoc server just fine from the end client.
Any tips or suggestions are helpful. Hopefully i have not missed something simple, but I am willing to look like a fool on the internet if it solves this problem, and maybe helps someone else.
I really like Seafile and would like to use it for my home file management. If I cannot get Seadoc working, it is not the end of the world. From reading many forum posts and github issues trying to dig for a solution, it seems many people run into issues trying to terminate SSL outside of the seafile stack. My suggestion would be to include some additional guide on how to do an “http-only” seafile deployment for these kinds of users. Thank you all for your hard work on this project and for answering questions on this forum.
