@Community
How is the current state of Ceph integration working?
Does Seafile support native integration of RBD storage and can it guarantee that the Ceph connector will work when there is a new stable Ceph release? I am asking this because the past with Seafile has shown that some things were only updated with a larger delay, leaving some pro customers more or less stranded.
Does anybody use Seafile with CephFS instead of native RBD?
Why is Ceph only supported for the Pro Edition?
This is a storage backend and doesn’t necessarily require a Seafile cluster.
@daniel.pan It would be great if Ceph,S3 and Swift would be supported in the CE as well, allowing us to use safer and large storage backend.
As said above this doesn’t mean that a Seafile cluster is required.
Thanks!
