My seafile desktop client stopped working, probably after upgrade. Web client works fine.
In nginx error log there’s:
client closed connection while SSL handshaking
In Seafile client:
start to serve on pipe client
failed to send rpc call: Broken pipe
How do I fix this? Thanks
Upgrading Seafile didn’t help, Windows client works fine
Noticed this error in syslog:
seafile-applet[1164242]: (…/…/…/glib/gerror.c:763):g_error_new_valist: runtime check failed: (domain != 0)
I have a very similar problem, did you manage to solve it?
Not sure, renewed cert, probably disabled verify certificate in the client
