First of all, I want to thank the developers for creating such a handy tool like Seafile. It has been a great addition to my workflow, allowing me to integrate cloud drive seamlessly into my Linux environment.
Currently, I’m working on customizing the client to better fit my specific needs. However, the documentation only provides an example configuration file, which is a good starting point but doesn’t cover all the possible configuration options.
Additionally, I have a specific use case in mind: I would like seadrive-fuse to automatically skip temporary files created by WPS Office, such as .~DOCUMENT.docx. If there’s a configuration option to achieve this, it would be incredibly helpful.
I would really appreciate it if there were a resource that lists all the available configuration options for seadrive-fuse. Having a comprehensive list would help me understand and utilize the full potential of the client.
Thank you for your hard work and dedication.
