I’ve deployed Seafile Server Professional (latest release) on Ubuntu Server 18.04 behind nginx, created and populated several repos / Libraries and am attempting to download and sync them externally using the CLI client on another Ubuntu 18.04 box.
My repos vary in size between 7.7 GB and 140GB.
Repos below 50gb are downloading without issue, but anything above that size is returning an ‘unknown error’, with log entries as the below example.
[04/24/20 10:43:19] http-tx-mgr.c(4145): Bad response code for POST https://seafile.mydomain.com/seafhttp/repo/60b9212b-9be3-4525-8d3d-3d17f917adb8/pack-fs/: 0.
[04/24/20 10:43:19] http-tx-mgr.c(4572): Failed to get fs objects for repo 60b9212b on server https://seafile.mydomain.com.
[04/24/20 10:43:19] http-tx-mgr.c(1157): Transfer repo '60b9212b': ('normal', 'fs') --> ('error', 'finished')
[04/24/20 10:43:19] clone-mgr.c(697): Transition clone state for 60b9212b from [fetch] to [error]: Unknown error.
Based on my reading so far, I believe there is an issue with my nginx configuration, which is below:
server_name seafile.mydomain.com;
server_tokens off;
proxy_set_header Host $host;
proxy_read_timeout 1200s;
proxy_buffer_size 16k;
proxy_busy_buffers_size 16k;
# logs
proxy_connect_timeout 36000s;
proxy_read_timeout 36000s;
proxy_request_buffering off;
send_timeout 36000s;
location /seafdav {
fastcgi_pass 127.0.0.1:8080;
access_log /var/log/nginx/seafdav.access.log seafileformat;
listen 443 ssl; # managed by Certbot
ssl_certificate /etc/letsencrypt/live/seafile.mydomain.com/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/seafile.mydomain.com/privkey.pem; # managed by Certbot
if ($host = seafile.mydomain.com) {
} # managed by Certbot
listen 80;
return 404; # managed by Certbot
I’m a little out of my league here so would appreciate any pointers from more experienced people.
