I am having trouble getting a docker installation of seafile server CE 11 to work behind apache as a reverse proxy.
In the long shot, I will need to migrate our current manual installation of seafile 9 to that, but for now I can’t even get a fresh new install to work.
The installation should be reachable by https://cloud.ourdomain.com
. There is an apache webserver on the machine “ourdomain.com
” serving several subdomains, including this one. It is accepting requests via HTTPS and reverse-proxying them to http://127.0.0.1:8000/
. That is the current setup, and I thought it should work the same with docker, but it doesn’t.
I have the container up and running with host port 8000 being redirected to container port 80. This works so far that I get a login page, but after that I get a CSRF verification failed error and can’t get past it.
I have read numerous pages here and elsewhere and tried setting SERVICE_URL to https://cloud.ourdomain.com
as well as setting CSRF_TRUSTED_ORIGINS=["https://cloud.ourdomain.com"];
I tried changing “proxy_set_header X-Forwarded-Proto https;
” as well as “proxy_set_header Host $host:8000;
” in the container’s nginx conf, and several combinations of these - none worked.
Is there any definitive guide how to get this setup working?
Thanks!
