I tried built seafile myself on my Synology NAS (armv7) by following the the instructions at https://manual.seafile.com/build_seafile/server.html. Although I was able to successfully build seafile and its dependencies, I was not able to start it and access seahub.
To rule out any platform-specific limitations I repeated the build in a Ubuntu 16.04 docker container on Mac OS but with exactly the same result.
After startup via seafile-admin start seahub always returns an internal server error:
curl -v http://127.0.0.1:8000
* Rebuilt URL to: http://127.0.0.1:8000/
* Trying 127.0.0.1...
* Connected to 127.0.0.1 (127.0.0.1) port 8000 (#0)
> GET / HTTP/1.1
> Host: 127.0.0.1:8000
> User-Agent: curl/7.47.0
> Accept: */*
< HTTP/1.1 500 Internal Server Error
< Connection: close
< Content-Type: text/html
< Content-Length: 141
<html>
<head>
<title>Internal Server Error</title>
</head>
<body>
<h1><p>Internal Server Error</p></h1>
</body>
</html>
These are the steps to reproduce:
# create container
docker run -it --name ubuntu-16.04-xenial ubuntu:16.04 /bin/bash
# install dependencies
apt-get update
apt-get -y install \
libevent-dev \
libcurl4-openssl-dev \
libglib2.0-dev \
uuid-dev \
intltool \
libsqlite3-dev \
libmysqlclient-dev \
libarchive-dev \
libtool \
libjansson-dev \
valac \
libfuse-dev
# the following dependency is not listed in the build instructions but it is needed for compiling ccnet-server
apt-get -y install libssl-dev
# install generic tools
wget \
make \
cmake \
g++
# build libevhtp
cd /opt
wget https://github.com/ellzey/libevhtp/archive/1.1.6.tar.gz
cmake -DEVHTP_DISABLE_SSL=ON -DEVHTP_BUILD_SHARED=OFF .
tar xf 1.1.6.tar.gz
cd libevhtp-1.1.6/
make
make install
# install seahub dependencies
python-dev \
python-setuptools
easy_install pip
pip install django==1.8.19
pip install pytz
pip install django-statici18n
pip install djangorestframework
pip install django_compressor
pip install django-post_office
pip install django-constance
pip install gunicorn
pip install flup
pip install chardet
pip install urllib3
pip install python-dateutil
pip install six
# the following dependencies are not listed in the build instructions but they are needed
pip install openpyxl
pip install jsonfield
pip install pillow
pip install django-picklefield
# download the artifacts and populate directory layout:
SEAFILE_VERSION=6.2.5
SEAFILE_HOME=/opt/seafile
SEAFILE_SERVER_HOME=${SEAFILE_HOME}/seafile-server
mkdir -p $SEAFILE_SERVER_HOME
cd $SEAFILE_SERVER_HOME
mkdir src
cd src
wget https://github.com/haiwen/libsearpc/archive/v3.0-latest.tar.gz
tar xf v3.0-latest.tar.gz
rm v3.0-latest.tar.gz
ln -s libsearpc-3.0-latest libsearpc-${SEAFILE_VERSION}-server
wget https://github.com/haiwen/ccnet-server/archive/v${SEAFILE_VERSION}-server.tar.gz
tar xf v${SEAFILE_VERSION}-server.tar.gz
rm v${SEAFILE_VERSION}-server.tar.gz
wget https://github.com/haiwen/seafile-server/archive/v${SEAFILE_VERSION}-server.tar.gz
wget https://github.com/haiwen/seahub/archive/v${SEAFILE_VERSION}-server.tar.gz
mv seahub-${SEAFILE_VERSION}-server seahub
# build libsearpc
cd ${SEAFILE_SERVER_HOME}/src/libsearpc-*-server
./autogen.sh
./configure
make
make install
# build ccnet-server
cd ${SEAFILE_SERVER_HOME}/src/ccnet-server-*-server
./autogen.sh
./configure --without-postgresql --with-mysql=/usr/bin/mariadb_config
make
make install
# build seafile-server
cd ${SEAFILE_SERVER_HOME}/src/seafile-server-*-server
./autogen.sh
make
make install
# run setup
cd ${SEAFILE_HOME}
export PYTHONPATH=$SEAFILE_SERVER_HOME/seahub/thirdpart
seafile-admin setup
This is your configuration
ccnet conf dir: /opt/seafile/ccnet
server name: diskstation
server host: 127.0.0.1
ccnet port: 10001
seafile data dir: /opt/seafile/seafile-data
seafile port: 12001
seafile fileserver port: 8082
Your seafile server configuration has been finished successfully.
# start seafile server
seafile-admin start
Starting seafile-server...
Starting seahub...
Seahub running on port 8000
Done
cat logs/ccnet.log
[04/16/18 19:49:41] ../common/session.c(132): using config file /opt/seafile/conf/ccnet.conf
[04/16/18 19:49:41] ../common/session.c(484): Listen on /opt/seafile/ccnet/ccnet.sock for local clients
[04/16/18 19:49:41] ../common/session.c(290): Update pubinfo file
[04/16/18 19:49:41] ../common/connect-mgr.c(515): Opened port 10001 to listen for incoming peer connections
[04/16/18 19:49:42] ../common/session.c(398): Accepted a local client
cat logs/controller.log
[04/16/18 19:49:41] seafile-controller.c(154): starting ccnet-server ...
[04/16/18 19:49:41] seafile-controller.c(73): spawn_process: ccnet-server -F /opt/seafile/conf -c /opt/seafile/ccnet -f /opt/seafile/logs/ccnet.log -d -P /pids/ccnet.pid
[04/16/18 19:49:41] seafile-controller.c(88): spawned ccnet-server, pid 22951
[04/16/18 19:49:42] seafile-controller.c(555): ccnet daemon connected.
[04/16/18 19:49:42] seafile-controller.c(186): starting seaf-server ...
[04/16/18 19:49:42] seafile-controller.c(73): spawn_process: seaf-server -F /opt/seafile/conf -c /opt/seafile/ccnet -d /opt/seafile/seafile-data -l /opt/seafile/logs/seafile.log -P /pids/seaf-server.pid
[04/16/18 19:49:42] seafile-controller.c(88): spawned seaf-server, pid 22954
[04/16/18 19:49:42] seafile-controller.c(528): seafdav not enabled.
cat logs/seafile.log
[04/16/18 19:49:42] http-server.c(161): fileserver: worker_threads = 10
[04/16/18 19:49:42] http-server.c(176): fileserver: fixed_block_size = 8388608
[04/16/18 19:49:42] http-server.c(191): fileserver: web_token_expire_time = 3600
[04/16/18 19:49:42] http-server.c(206): fileserver: max_indexing_threads = 1
[04/16/18 19:49:42] ../common/mq-mgr.c(54): [mq client] mq cilent is started
[04/16/18 19:49:42] listen-mgr.c(120): listen on port 12001 for block tranfer
[04/16/18 19:49:42] seafile-session.c(331): Failed to open template dir /opt/seafile/seafile-data/library-template: Error opening directory '/opt/seafile/seafile-data/library-template': No such file or directory.
[04/16/18 19:49:43] size-sched.c(96): Repo size compute queue size is 0
root@6b8a4928917f:/opt/seafile#
Creating /opt/seafile/seafile-data/library-template did not help. seahub specific logs are stored into /tmpbut empty:
ll /tmp/
+total 12
drwxrwxrwt 3 root root 4096 Apr 16 19:55 ./
drwxr-xr-x 44 root root 4096 Apr 16 19:49 ../
-rw-r--r-- 1 root root 0 Apr 16 19:47 seahub.log
drwx------ 2 root root 4096 Apr 16 19:55 seahub_cache/
-rw-r--r-- 1 root root 0 Apr 16 19:47 seahub_django_request.log
