Log in to Docker with Seafile account
docker login docker.seadrive.org
- username:
seafile - password:
zjkmid6rQibdZ=uJMuWS
Run Docker Compose
docker compose up -d
Check if all containers are running
docker compose ps -a
- If the display looks like the one above, there is a container error. Check the logs:
docker logs seafile-ldap
- You need to grant write permission to the directory:
sudo chmod -R 777 ./data-volumn-docker/
docker compose restart
- Then, access
http://localhost:8090- user:
admin@example.com - pass:
admin
- user:
Copy frontend files from the container to the host machine
docker cp seafile:/opt/seafile/seafile-pro-server-11.0.14/seahub/frontend ./frontend
- It will show the following result, and you should see the frontend folder:
test@test:~/Documents/seafile/setup-seafile-pe-docker$ docker cp seafile:/opt/seafile/seafile-pro-server-11.0.14/seahub/frontend ./frontend
Successfully copied 5.95MB to /home/test/Documents/seafile/setup-seafile-pe-docker/frontend
Modify configuration file
- Edit the file
./data-volumn-docker/seafile-data/seafile/conf/seahub_settings.py - Add the following code at the beginning:
import os
PROJECT_ROOT = '/opt/seafile/seafile-pro-server-11.0.14/seahub'
WEBPACK_LOADER = {
'DEFAULT': {
'BUNDLE_DIR_NAME': 'frontend/',
'STATS_FILE': os.path.join(PROJECT_ROOT,
'frontend/webpack-stats.dev.json'),
DEBUG = True
# -*- coding: utf-8 -*-
- Restart the container:
When you access
localhost:8090, the following error will appear:
Go to the frontend directory (note: use Node v16):
npm i
npm run dev
- Wait until the following is displayed:
Listening at http://0.0.0.0:3000/assets/bundles/
webpack compiled successfully
Next, uncomment line 72 in the docker-compose file ./frontend:/opt/seafile/seafile-pro-server-11.0.14/seahub/frontend
- Then, reset the container
docker compose down
Access again, you will see the following result:
Try changing the UI in the file
./frontend/src/components/side-panel.jsand see the result:
You will see the terminal in the frontend automatically compiled after each change.
Wish you a successful installation!
