I noticed that on 9.0.2 some users can’t log in when they come from an IPv6 address.
Seahub reports:
[ERROR] django.request:230 log_response Internal Server Error: /accounts/login/
File "/opt/seafile/seafile-server-9.0.2/seahub/thirdpart/django/db/backends/utils.py", line 84, in _execute
File "/opt/seafile/seafile-server-9.0.2/seahub/thirdpart/django/db/backends/mysql/base.py", line 73, in execute
File "/usr/local/lib/python3.7/dist-packages/MySQLdb/cursors.py", line 206, in execute
res = self._query(query)
File "/usr/local/lib/python3.7/dist-packages/MySQLdb/cursors.py", line 319, in _query
db.query(q)
File "/usr/local/lib/python3.7/dist-packages/MySQLdb/connections.py", line 254, in query
_mysql.connection.query(self, query)
MySQLdb._exceptions.DataError: (1406, "Data too long for column 'login_ip' at row 1")
So I went into the MySQL seahub DB and issued alter table sysadmin_extra_userloginlog modify column login_ip varchar(45) not null; which fixed it. Is this a known bug? Or some misconfiguration on my side? I ran all upgrade scripts as far as I can tell.
Stefan
