I want to use Seafile Pro for S3 support.
But I’m not interested on any other Pro functionalities… Is it possible to activate/deactivate specific features? For example, Java instances/support?
Thank you
Hello!
You can disable quite some features via the config files (especially seahub_settings.py). You can disable search, file preview, audit log for instance. You find more info in the Seafile manual at https://download.seafile.com/published/seafile-manual/config
Additionally, you can create/define roles in a way that all pro features (such as ‘Invite users’) are disabled. You find more info on roles and permissions here: https://download.seafile.com/published/seafile-manual/deploy_pro/roles_permissions.md
I am positive that you can achieve your objective by strictly disabling features you don’t want/need.
Disable search in seafevents.conf.
Thank you both
I’ll set today a small VM and check that Java is not executed at all
How do you want to check that. Only proper way is to uninstall Java and see what happens
