hello
i have problems, on a new seafile 11 on debian 12.
first, the “Freeze option” not work for a LDAP account.
and i cannot use fail2ban, because, even if some users are only local, in seahub.log i see only auth error, without the users ip.
help? ![]()
for exemple:
the first 4 lines are for a local user, and the next 4 for a ldap user.
Blockquote
2024-12-19 13:23:14,765 [ERROR] seahub.base.accounts:1004 authenticate ldap user 35255ff28824452086621b35a8a67e78@auth.local not found.
2024-12-19 13:23:28,318 [ERROR] seahub.base.accounts:1004 authenticate ldap user 35255ff28824452086621b35a8a67e78@auth.local not found.
2024-12-19 13:23:32,294 [ERROR] seahub.base.accounts:1004 authenticate ldap user 35255ff28824452086621b35a8a67e78@auth.local not found.
2024-12-19 13:23:36,157 [ERROR] seahub.base.accounts:1004 authenticate ldap user 35255ff28824452086621b35a8a67e78@auth.local not found.
2024-12-19 13:37:56,747 [ERROR] seahub.base.accounts:1004 authenticate ldap bind failed: {‘msgtype’: 97, ‘msgid’: 1, ‘result’: 49, ‘desc’: ‘Invalid credentials’, ‘ctrls’: , ‘info’: ‘80090308: LdapErr: DSID-0C0903A9, comment: AcceptSecurityContext error, data 52e, v1db1’}
2024-12-19 13:38:02,089 [ERROR] seahub.base.accounts:1004 authenticate ldap bind failed: {‘msgtype’: 97, ‘msgid’: 1, ‘result’: 49, ‘desc’: ‘Invalid credentials’, ‘ctrls’: , ‘info’: ‘80090308: LdapErr: DSID-0C0903A9, comment: AcceptSecurityContext error, data 52e, v1db1’}
2024-12-19 13:38:09,857 [ERROR] seahub.base.accounts:1004 authenticate ldap bind failed: {‘msgtype’: 97, ‘msgid’: 1, ‘result’: 49, ‘desc’: ‘Invalid credentials’, ‘ctrls’: , ‘info’: ‘80090308: LdapErr: DSID-0C0903A9, comment: AcceptSecurityContext error, data 52e, v1db1’}
2024-12-19 13:38:14,462 [ERROR] seahub.base.accounts:1004 authenticate ldap bind failed: {‘msgtype’: 97, ‘msgid’: 1, ‘result’: 49, ‘desc’: ‘Invalid credentials’, ‘ctrls’: , ‘info’: ‘80090308: LdapErr: DSID-0C0903A9, comment: AcceptSecurityContext error, data 52e, v1db1’}
