I’m on pro 6.2.13 / Debian 8
I noticed that we have to move bundled LDAP libraries to make LDAP authentication work on Debian
On the manual
https://manual.seafile.com/deploy_pro/using_ldap_pro.html
cd ${SEAFILE_INSTALLATION_DIR}/seafile-server-latest/seafile/lib
mkdir disabled_libs_use_local_ones_instead
mv liblber-2.4.so.2 libldap-2.4.so.2 libsasl2.so.2 libldap_r-2.4.so.2 disabled_libs_use_local_ones_instead/
Cf.
But
- libsasl2.so.2 does not exist in lib folder
- this is a annoying maintenance task
Could it be fixed @daniel.pan ?
regards
