I need Help with my Seafile Server. I am using a raspberry Pi with an external Harddisk and sata Adapter.
Some time ago i hat to freshly install my server and the backup was pretty broken. I struggeled a lot with setting a new server up because the db files are not in order and i cant import them somehow. But i managed to export a few files with seaf-fsck and rescued them. The Problem is now that the majority of my files are in encrypted libraries and it returned:
"[12/30/19 13:25:53] fsck.c(1108): The following repos are encrypted and are not exported:
[12/30/19 13:25:53] fsck.c(1058): 373c220c-4e41-44b5-b00b-4c2dbaa31761(Priv)
[12/30/19 13:25:53] fsck.c(1058): 27a45b1f-0c01-4af1-900f-afff37924331(xyz)
[12/30/19 13:25:53] fsck.c(1058): 43cf7b0d-9741-4205-af1e-314fab2a9bd7(example)
[12/30/19 13:25:53] fsck.c(1058): 62c8bae8-52be-463e-ad33-11d361f0c0e1(Testfiles)
[12/30/19 13:25:53] fsck.c(1058): c9cf5628-2eb3-4713-aa0f-71e5bd87dc00(Privat)
[12/30/19 13:25:53] fsck.c(1058): 6d99ea4d-31cb-4b17-9150-be56eabd52b6(Doc)
[12/30/19 13:25:53] fsck.c(1058): e293ca3e-4294-4b03-80b2-d9cf1d0a698f(Music)
[12/30/19 13:25:53] fsck.c(1058): b8b991d9-7373-44d5-8cc0-cd0c5a77ffb3(DB)
My question is now: is it possible to manually decrypt those libraries? I mean it could just prompt for a password when exporting those files. There has to be a way to decrypt them without setting up a new seafile server and all the Database struggle. I hope you can help me. Some of this data is very important to me. Thank you.
