hello, for reasons i want to get away from docker-compose and could not find a guide for deploying saefile server 7 with docker run. i transfered the commands in shellscript-files (first time for me) and tested it. database immediately exits (log files don’t help so far) and my desired subdomain is not reachable - “connection refused”.
do i have to start the containers in a specific order? i startet with memcached, then datadabe, then seafile itself.
here is my config, maybe someone can check for usual mistakes or so? btw.: i uses podman instead of docker, but syntax is the same, should work the same.
#!/bin/bash
podman run -d --name seafile -e SEAFILFE_SERVER_HOSTNAME=“file.mydomain” -e SEAFILE_SERVER_LETSENCRYPT=“true” -v
/opt/seafile-data:/shared -e DB_HOST=“db” -e DB_ROOT_PASSWD=“longpasshere” -e TIME_ZONE=“Etc./UTC” -e
SEAFILE_ADMIN_EMAIL="mail@mail.com" -e SEAFILE_ADMIN_PASSWORD=“longpasshere” --network=“seafile” --restart always -p
80:80 -p 443:443 seafileltd/seafile-mc:latest
!/bin/bash
podman run -d --name seafile-memcached --entrypoint memcached --network=“seafile” memcached:1.5.6
#!/bin/bash
podman run -d --name seafile-db -e MYSQL_ROOT_PASSWORD=“longpasshere” -e MYSQL_LOG_CONSOLE=“true” -v
/opt/seafile-mysql/db:/var/lib/mysql --network=“seafile” mariadb:10.1
