Any one using Mac Desktop Drive Clients on Catalina?
Mine crashed upon start once I upgraded to Catalina.
Edit;
Error Message “SeadDrive Failed to initialise”
Edit;
I saw this on a website,
I don’t know if there’s a relationship.
Your 32-bit apps are no longer going to work in macOS Catalina, and you’ll get a warning when you install the update. macOS Catalina supports 64-bit apps only
According to Apple’s System Information app 10.14 both SeaDrive 1.0.7 and Seafile Client 7.0.2 are 64-bit apps.
Hi, i have a user with Catalina who installed 10.0.11 drive and have the same issue with error message “osxfuse damaged”
I’ll be glad to know if there is a workaround …
Regards,
Gautier
