my certificate expired today.
The auto renew didn’t work.
I stopped and started the container and it returns the follwing which indicates that the ssl.sh script tries to pull something from git and failed.
Is there any update? I am running 9.0.4.
thanks! Till
seafile | *** Running /etc/my_init.d/01_create_data
_links.sh…
seafile | *** Booting runit daemon…
seafile | *** Runit started as PID 25
seafile | *** Running /scripts/enterpoint.sh…
seafile | 2022-03-28 17:42:54 Waiting Nginx
seafile | 2022-03-28 17:42:55 Nginx ready
seafile | 2022-03-28 17:42:55 This is a idle script (infinite loop) to keep container running.
seafile | Certificate will expire
seafile | fatal: remote error:
seafile | The unauthenticated git protocol on port 9418 is no longer supported.
seafile | Please see Improving Git protocol security on GitHub | The GitHub Blog for more information.
seafile | [2022-03-28 17:42:55] Preparing for letsencrypt …
seafile | [2022-03-28 17:42:55] Found existing cert file /shared/ssl/.crt
seafile | [2022-03-28 17:42:55] Starting letsencrypt verification
seafile | File “/scripts/start.py”, line 86, in
seafile | main()
seafile | File “/scripts/start.py”, line 51, in main
seafile | init_letsencrypt()
seafile | File “/scripts/bootstrap.py”, line 80, in init_letsencrypt
seafile | call(’/scripts/ssl.sh {0} {1}’.format(ssl_dir, domain))
seafile | File “/scripts/utils.py”, line 70, in call
seafile | return subprocess.check_call(*a, **kw)
seafile | File “/usr/lib/python3.8/subprocess.py”, line 364, in check_call
seafile | raise CalledProcessError(retcode, cmd)
seafile | subprocess.CalledProcessError: Command '/scripts/ssl.sh /shared/ssl ’ returned non-zero exit status 1.
