I can’t seem to get the seafile image up and running anymore, other three images run ok… I’ve removed the image and now when I run docker compose up -d on by raspberry pi 4 OS Debian 12 I now get the following.
"The requested image’s platform (linux/amd64) does not match the detected host platform (linux/arm64/v8) and no specific platform was requested "
I’m trying to pull docker.seadrive.org-seafileltd-seafile-pro-mc:latest
They are a bit behind with providing multiarch images. You need to pull the arm version explicitly.
docker pull docker.seadrive.org/seafileltd/seafile-pro-mc:10.0.13-arm
Thanks so much, that did the trick. All my files are back!
I looked for a list of images on the website and tried to search for them after logging in with docker search but didn’t have any luck
Is there a list of images somewhere convenient where I can keep up with things?
Many thanks.
You can check it out here: https://docker.seadrive.org/
You’ll need the login from the customer portal: https://customer.seafile.com/ (Not the login TO the customer portal, but you’ll find the login for harbor in the customer portal).
