I have issues getting Seafile to work in a docker lxc on Proxmox.
It was working fine in a VM with an SMB share, but I decided to create different VMs and LXCs for different services.
This is my current compose file:
db:
image: ${SEAFILE_DB_IMAGE:-mariadb:10.11}
container_name: seafile-mysql
restart: unless-stopped
- MYSQL_ROOT_PASSWORD=${SEAFILE_MYSQL_ROOT_PASSWORD:-}
- MYSQL_LOG_CONSOLE=true
- MARIADB_AUTO_UPGRADE=1
- "${SEAFILE_MYSQL_VOLUME:-/opt/seafile-mysql/db}:/var/lib/mysql"
networks:
- seafile-net
healthcheck:
test:
"CMD",
"/usr/local/bin/healthcheck.sh",
"--connect",
"--mariadbupgrade",
"--innodb_initialized",
interval: 20s
start_period: 30s
timeout: 5s
retries: 10
redis:
image: ${SEAFILE_REDIS_IMAGE:-redis}
container_name: seafile-redis
command:
- /bin/sh
- -c
- redis-server --requirepass "$$REDIS_PASSWORD"
- REDIS_PASSWORD=${REDIS_PASSWORD:-}
networks:
- seafile-net
seafile:
image: ${SEAFILE_IMAGE:-seafileltd/seafile-mc:13.0-latest}
# ports:
# - "80:80"
- SEAFILE_MYSQL_DB_HOST=${SEAFILE_MYSQL_DB_HOST:-db}
- SEAFILE_MYSQL_DB_PORT=${SEAFILE_MYSQL_DB_PORT:-3306}
- SEAFILE_MYSQL_DB_USER=${SEAFILE_MYSQL_DB_USER:-seafile}
- SEAFILE_MYSQL_DB_PASSWORD=${SEAFILE_MYSQL_DB_PASSWORD:?Variable is not set or empty}
- SEAFILE_MYSQL_ROOT_PASSWORD=${SEAFILE_MYSQL_ROOT_PASSWORD:-}
- SEAFILE_MYSQL_DB_CCNET_DB_NAME=${SEAFILE_MYSQL_DB_CCNET_DB_NAME:-ccnet_db}
- SEAFILE_MYSQL_DB_SEAFILE_DB_NAME=${SEAFILE_MYSQL_DB_SEAFILE_DB_NAME:-seafile_db}
- SEAFILE_MYSQL_DB_SEAHUB_DB_NAME=${SEAFILE_MYSQL_DB_SEAHUB_DB_NAME:-seahub_db}
- TIME_ZONE=${TIME_ZONE:-Etc/UTC}
- SEAFILE_ADMIN_EMAIL=${SEAFILE_ADMIN_EMAIL:-me@example.com}
- SEAFILE_ADMIN_PASSWORD=${SEAFILE_ADMIN_PASSWORD:-asecret}
- SEAFILE_SERVER_HOSTNAME=${SEAFILE_SERVER_HOSTNAME:?Variable is not set or empty}
- SEAFILE_SERVER_PROTOCOL=${SEAFILE_SERVER_PROTOCOL:-http}
- SITE_ROOT=${SITE_ROOT:-/}
- NON_ROOT=${NON_ROOT:-false}
- JWT_PRIVATE_KEY=${JWT_PRIVATE_KEY:?Variable is not set or empty}
- SEAFILE_LOG_TO_STDOUT=${SEAFILE_LOG_TO_STDOUT:-false}
- ENABLE_SEADOC=${ENABLE_SEADOC:-true}
- SEADOC_SERVER_URL=${SEAFILE_SERVER_PROTOCOL:-http}://${SEAFILE_SERVER_HOSTNAME:?Variable is not set or empty}/sdoc-server
- CACHE_PROVIDER=${CACHE_PROVIDER:-redis}
- REDIS_HOST=${REDIS_HOST:-redis}
- REDIS_PORT=${REDIS_PORT:-6379}
- MEMCACHED_HOST=${MEMCACHED_HOST:-memcached}
- MEMCACHED_PORT=${MEMCACHED_PORT:-11211}
- ENABLE_NOTIFICATION_SERVER=${ENABLE_NOTIFICATION_SERVER:-false}
- INNER_NOTIFICATION_SERVER_URL=${INNER_NOTIFICATION_SERVER_URL:-http://notification-server:8083}
- NOTIFICATION_SERVER_URL=${NOTIFICATION_SERVER_URL:-${SEAFILE_SERVER_PROTOCOL:-http}://${SEAFILE_SERVER_HOSTNAME:?Variable is not set or empty}/notification}
- ENABLE_SEAFILE_AI=${ENABLE_SEAFILE_AI:-false}
- SEAFILE_AI_SERVER_URL=${SEAFILE_AI_SERVER_URL:-http://seafile-ai:8888}
- SEAFILE_AI_SECRET_KEY=${JWT_PRIVATE_KEY:?Variable is not set or empty}
- MD_FILE_COUNT_LIMIT=${MD_FILE_COUNT_LIMIT:-100000}
labels:
caddy: ${SEAFILE_SERVER_PROTOCOL:-http}://${SEAFILE_SERVER_HOSTNAME:?Variable is not set or empty}
depends_on:
db:
condition: service_healthy
redis:
condition: service_started
networks:
- seafile-net
caddy:
container_name: seafile-caddy
- 443:443
- /var/run/docker.sock:/var/run/docker.sock
- ${SEAFILE_CADDY_VOLUME:-/opt/seafile-caddy}:/data/caddy
networks:
- seafile-net
healthcheck:
test: ["CMD-SHELL", "curl --fail http://localhost:2019/metrics || exit 1"]
start_period: 20s
interval: 20s
timeout: 5s
retries: 3
seadoc:
image: ${SEADOC_IMAGE:-seafileltd/sdoc-server:2.0-latest}
container_name: seadoc
- ${SEADOC_VOLUME:-/opt/seadoc-data/}:/shared
# ports:
# - "80:80"
- DB_PORT=${SEAFILE_MYSQL_DB_PORT:-3306}
- DB_USER=${SEAFILE_MYSQL_DB_USER:-seafile}
- DB_PASSWORD=${SEAFILE_MYSQL_DB_PASSWORD:?Variable is not set or empty}
- DB_NAME=${SEADOC_MYSQL_DB_NAME:-seahub_db}
- SEAHUB_SERVICE_URL=${SEAFILE_SERVICE_URL:-http://seafile}
labels:
caddy.@ws.0_header: "Connection *Upgrade*"
caddy.@ws.1_header: "Upgrade websocket"
caddy.0_reverse_proxy: "@ws {{upstreams 80}}"
caddy.1_handle_path: "/socket.io/*"
caddy.1_handle_path.0_rewrite: "* /socket.io{uri}"
caddy.1_handle_path.1_reverse_proxy: "{{upstreams 80}}"
caddy.2_handle_path: "/sdoc-server/*"
caddy.2_handle_path.0_rewrite: "* {uri}"
caddy.2_handle_path.1_reverse_proxy: "{{upstreams 80}}"
depends_on:
db:
networks:
- seafile-net
networks:
seafile-net:
And this my .env:
## Images
SEAFILE_IMAGE=seafileltd/seafile-mc:13.0-latest
SEAFILE_REDIS_IMAGE=redis
SEAFILE_CADDY_IMAGE=lucaslorentz/caddy-docker-proxy:2.9-alpine
SEADOC_IMAGE=seafileltd/sdoc-server:2.0-latest
## Persistent Storage
#BASIC_STORAGE_PATH=/opt
BASIC_STORAGE_PATH=/mnt/seafile
SEAFILE_MYSQL_VOLUME=$BASIC_STORAGE_PATH/seafile-mysql/db
SEAFILE_CADDY_VOLUME=$BASIC_STORAGE_PATH/seafile-caddy
# Startup parameters #
SEAFILE_SERVER_HOSTNAME=XXX
SEAFILE_SERVER_PROTOCOL=http
TIME_ZONE=Europe/Berlin
JWT_PRIVATE_KEY=xXX
# Third-party service configuration #
## Database
SEAFILE_MYSQL_DB_HOST=db
SEAFILE_MYSQL_DB_USER=seafile
SEAFILE_MYSQL_DB_PASSWORD=XXX
## Cache
CACHE_PROVIDER=redis # or memcached
### Redis
REDIS_HOST=redis
REDIS_PORT=6379
REDIS_PASSWORD=XXX
### Memcached
MEMCACHED_HOST=memcached
MEMCACHED_PORT=11211
# Initial variables #
# (Only valid in first-time startup) #
## Database root password, Used to create Seafile users
SEAFILE_MYSQL_ROOT_PASSWORD=XXX
## Seafile admin user
SEAFILE_ADMIN_EMAIL=XXX
SEAFILE_ADMIN_PASSWORD=XXX
# Additional configurations for extensions #
## SeaDoc service
ENABLE_SEADOC=true
## Notification
ENABLE_NOTIFICATION_SERVER=false
## Seafile AI
ENABLE_SEAFILE_AI=false
SEAFILE_AI_LLM_URL=
SEAFILE_AI_LLM_KEY=
## Metadata server
MD_FILE_COUNT_LIMIT=100000
I mounted the SMB share to the LXC like described here.
Proxmox Forum:
/threads/tutorial-unprivileged-lxcs-mount-cifs-shares.101795/
This works perfectly fine for other services and Iām able to create files and folder in the LXC on the share, and it creates all the folders for the DB and Seafile etc. but I get this error during startup for the mysql container:
seafile-mysql | 2025-08-08 14:44:14+00:00 [Note] [Entrypoint]: Initializing database files
seafile-mysql | 2025-08-08 14:44:14 0 [Warning] Canāt create test file ā/var/lib/mysql/0ca35996907d.lower-testā (Errcode: 13 āPermission deniedā)
seafile-mysql | /usr/sbin/mariadbd: Canāt change dir to ā/var/lib/mysql/ā (Errcode: 13 āPermission deniedā)
seafile-mysql | 2025-08-08 14:44:14 0 [ERROR] Aborting
Anybody got this working already?
