In official docker-compose file, there are 3 services. MariaDB, Seafile and memcached. MariaDB is set up with name of “db” and is later referenced as DB HOST in Seafile block. But memcached is not referenced in docker-compose by neither of the two other services. How is memcached wired up to seafile or database?
Via the config files in the seafile container.
Can you please point me to it? I can’t find it.
Check seahub_settings.py
The path to the file depends on the volume specification of the seafile container. The default path is - I think - /opt/seafile-data/seafile/conf
FWIW - within a docker-compose setup, whatever the container name is - you can use that name to reference from between containers. So as rdb pointed the configs - the name in the config has to match the container name in the docker-compose. If there’s no container name, then there’s a convention for docker. I don’t like the convention; so I have all my container named explicitly…
Thanks for the replies. I checked the seahub_settings.py, this is what’s in it:
CACHES = {
‘default’: {
‘BACKEND’: ‘django_pylibmc.memcached.PyLibMCCache’,
‘LOCATION’: ‘memcached:11211’,
‘locmem’: {
‘BACKEND’: ‘django.core.cache.backends.locmem.LocMemCache’,
I see here that the cache instances is identified as “memcached:11211”. However, my docker-compose.yml looks like this:
memcached:
image: memcached:1.6
container_name: seafile-redacted-net-memcached
hostname: seafile-redacted-net-memcached
entrypoint: memcached -m 256
networks:
- pra1-nginx
I belive, I should change the LOCATION value in seahub_settings.py to the HOSTNAME value in docker-compose.yml and that should be the correct way to do it.
I am surprised there are no complaints in the log that the instance for caching hasn’t been found.
Service name is an alias to the container (kind of), no alias is ever hidden by another. See:
docker-compose-yml
client:
image: ensignprojects/ubuntu-dnsutils
command: ["tail", "-f", "/dev/null"]
deploy:
mode: replicated
replicas: 2
networks:
- domain
server:
container_name: server_container
hostname: server_hostname
networks:
domain:
aliases:
- backend
data:
aliases:
- app
db:
# This won't work
# container_name: server_container
networks:
data:
aliases:
# Whoops, those are used somewhere else
- server_container
- server_hostname
networks:
domain:
data:
Everything you would expect just works fine:
$ docker compose exec client bash -c "host server && host server_container && host server_hostname && host backend && host app; host db"
server has address 172.31.0.2
server_container has address 172.31.0.2
server_hostname has address 172.31.0.2
backend has address 172.31.0.2
# host app - Expected since client does not belong to network data
;; connection timed out; no servers could be reached
# host db - Expected since client does not belong to any common network with db service
Note that even though a container name is unique, its alias on a network can easily be reused (as all others). See:
$ docker compose exec server bash -c "host client && host server_container && host server_hostname"
client has address 172.31.0.4
client has address 172.31.0.3
server_container has address 192.168.0.3
server_container has address 192.168.0.2
server_hostname has address 192.168.0.2
server_hostname has address 192.168.0.3
Everything resolves to two addresses in a random order because there are two containers by hostname. It’s now a total mess which won’t work as you expect but docker won’t complain in any way, so just be aware of it and deal with it.
