For maintenance upgrade, like from version 10.0.1 to version 10.0.4, just download the new image, stop the old docker container, modify the Seafile image version in docker-compose.yml to the new version, then start with docker compose up.
I don’t believe there is a docker-compose.yml file anymore.
The .env file refers to all the latest Seafile images:
Thanks @mercury for taking the time to answer, that solved it.
I haven’t done “docker compose pull” before.
I thought the script does this automatically and I didn’t know.
I have tried it and now it works.
docker compose pull
docker compose down
docker compose up -d
Great how simple it is!
Maybe it makes sense that this is being added to the manual (even if so simple).
Thanks again !
Edit: As a heads up: Once Seafile CE 14 is out officially, I am gonna ask again how to upgrade to that one Edit2: Well, that’s actually well documented. That should be alright
I’m glad that your problem is resolved but your issue is still unsolved for me. As I understand it, if you shutdown the stack it should clear the deck (so to speak) for the update that occurs when you start the server stack again (docker compose up -d) assuming the latest version of the image file is being specified and pulled. Any idea why that might not have happened?
