Docker Seafile CE 12 Upload very slow?!
hi!
i’ve migrated from “binary” seafile server edition to the docker based installion. all working fine include the notification server.
but the upload is very very very slow (300kb/s-800kb/s @ peak) .
is there any optimation option or how can i check where the “brake” is?
Hey,
i have the same problem, but speeds are worse:
Untitled
I tried with caddy as well as with nginx as proxy for public access.
Interestingly the speeds are ok if I upload a file natively on the machine itself.
I have a connection only over LAN (no WAN involved) from my computer to the server. Before migrating to docker I had read- and write-speeds around 75-85 MB/s.
Kind Regards
I investigated further by directly connecting my PC to over a cable and the speeds are great again. I really don’t know what happened but it seems to be a router problem translating from Wifi to LAN, even though my up- and download speeds Wifi↔WAN are fast. It’s only Wifi↔LAN which is slow and has lots of packet drops, but it’s the same network!
yes - with cable are very high speed / wlan slow
Enabling Packet-Steering in my OpenWRT improved speeds a bit, but it’s still far away from my normal wifi speed.
