I am struggling with setting up Docker-Seafile on my NanoPC-T6 running Ubuntu 24.04.
There are several other programs with network access running on the machine controlled by NGINX, so I wonder if Seafile traffic has to go through a Reverse Proxy (NGINX).
I have ‘separated’ Seafile, by using a sub-domain (https://seafile.xxxxx.com), and dedicated ports (8090, and 7443), and also use existing SSL cert and key.
This setup is implemented in:
/opt/seafiile/docker-compose.yml:
- "8090:80"
- "7443:443"
- /opt/seafile-data:/shared
- /etc/ssl/mail/mail.crt:/shared/ssl/mail.crt
- /etc/ssl/mail/mail.key:/shared/ssl/mail.key
- DB_HOST=db
- DB_ROOT_PASSWD=xxxxx
- TIME_ZONE=Asia/Singapore
- SEAFILE_ADMIN_EMAIL=seafile_adm@xxxxx.com
- SEAFILE_ADMIN_PASSWORD=xxxxxx
- FORCE_HTTPS_IN_CONF=true
- SEAFILE_SERVER_HOSTNAME=seafile.xxxxxx.com:7443
/opt/seafile-data/nginx/conf/seafile.nginx.conf :
listen 8090;
listen [::]:8090;
server_name seafile.xxxxx.com default_server;
rewrite ^ https://$host$request_uri? permanent;
listen 7443;
listen [::]:7443;
ssl_certificate /shared/ssl/mail.crt;
ssl_certificate_key /shared/ssl/mail.key;
ssl_ciphers ECDH+AESGCM:DH+AESGCM:ECDH+AES256:DH+AES256:ECDH+AES128:DH+AES:ECDH+3DES:DH+3DES:RSA+AESGCM:RSA+AES:RSA+3DES:!aNULL:!MD5:!DSS;
server_name seafile.xxxxx.com;
original, no changes
/opt/seafile-data/seafile/seahub_settings.py:
# -*- coding: utf-8 -*- SERVICE_URL = "https://seafile.xxxxxx.com:7443" ..... TIME_ZONE = 'Asia/Singapore' FILE_SERVER_ROOT = "https://seafile.xxxxxx.com:7443/seafhttp"
Netstat confirms both ports 8090 and 7443 are Listening:
tcp 0 0 0.0.0.0:7443 0.0.0.0:* LISTEN 0 240731 1306/dockerd
tcp 0 0 0.0.0.0:8090 0.0.0.0:* LISTEN 0 240730 1306/dockerd
The problem I am facing:
When opening ‘https://seafile.xxxx.com:7443’, i get ‘Unable to connect’, and there are no entries in any nginx-log-files.
This does not change if the server-NGINX is running or not.
The port-forwarding to ports 8090 and 7443 is working.
When starting the docker container: ‘docker compose up’, I do not see any errors.
What am i missing?
Do I need to configure an external Reverse proxy?
Thanks for your help!
