after 10 years of Seafile via packages, I wanted to take the first steps towards Docker with Seafile and at the same time change our storage to S3.
During testing, however, I encountered a problem. I would like to use SSE_C. This works fine as long as I don’t recreate the container.
As soon as I restart the container with “docker compose up -d --force-recreate”, I can no longer access the libraries. The S3 storage reports an error that not all the information is correct.
However, I can create a new library without any problem and use it until I recreate the container again. That would make updates very tricky ![]()
Is there something here that I have overlooked/need to save?
Error message from S3 storage: “The object was stored using a form of server-side encryption. The correct parameters must be specified to retrieve the object.”
Provider used: WASABI
If I deactivate SSE_C, it works perfectly, even after recreating the container.
I have tested it with the compose file from Datamate (as I prefer to work with environment variables) and the one from Seafile itself, same problem with both.
Do you have any ideas?
bye
Andre
Thank you very much for being part of the Seadays ![]()
