I have created a second container called seafilefinance, im trying to enable a https self signed certificate. But i cant get it working. http is fine.
Currently i have 2 docker containers in which seafile2 uses lets encrypt uses port 443 and 80, while seafilefinance uses port 81 and 444.
docker container ls output:
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES 2c68bf882571 seafileltd/seafile:latest "/sbin/my_init -- /s…" 28 hours ago Up 24 ho urs 0.0.0.0:81->80/tcp, 0.0.0.0:444->443/tcp seafilefinance 54925b0e2404 seafileltd/seafile:latest "/sbin/my_init -- /s…" 4 months ago Up 7 wee ks 0.0.0.0:80->80/tcp, 0.0.0.0:443->443/tcp seafile2
Here are the steps on how i configured it.
1.Create docker container
docker run -d --name seafilefinance
-e SEAFILE_SERVER_HOSTNAME=seafile.example.com
-e SEAFILE_ADMIN_EMAIL=me@example.com
-e SEAFILE_ADMIN_PASSWORD=a_very_secret_password
-v /opt/seafile-data-finance:/shared
-p 81:80
-p 444:443
2.Access the running container seafilefinance
3.Create self signed certificates.
openssl req -x509 -nodes -days 365 -newkey rsa:2048 -keyout /etc/ssl/private/nginx-selfsigned.key -out /etc/ssl/certs/nginx-selfsigned.crt
Edit the /etc/nginx/sites-available file
server { listen 80; listen 443 ssl http2; server_name localhost; ssl_certificate /etc/ssl/certs/nginx-selfsigned.crt; ssl_certificate /etc/ssl/private/nginx-selfsigned.key; ssl_protocols TLSv1.2 TLSv1.1 TLSv1; root /var/www/html; index index.html index.nginx-debian.html; }
5.check the nginx file ; nginx -t
6. service nginx restart
7. restart docker container to make sure.
Anything i missed out? i tried creating an nginx container with the same process as creating a self signed certificate above and its working. im wondering why the docker container doesnt.
