I am trying to run the seafile dockercompose file and have changed the data and database volumes to point to a locally mounted NFS share. I have been experimenting with various permutations of NFS/permissions/no_root_squash and /etc/fstab combinations but cannot get the docker-compose and associated containers to start up. (The NFS share is accessible and writeable by all the normal users and commands like touch, I only experience problems when using docker-compose and containers).
I’m now wondering if this is even possible before any spend any more days grappling with this. Should it be possible to use this docker-compose file without issue where /mnt/nfsprox is a mounted (via fstab) NFS share? If so I’m happy to spend more time fighting this…
version: ‘2.0’
db:
image: mariadb:10.11
container_name: seafile-mysql
- MYSQL_ROOT_PASSWORD=OBSCURED # Requested, set the root’s password of MySQL service.
- MYSQL_LOG_CONSOLE=true
- /mnt/nfsprox/seafile-volume/seafile-mysql/db:/var/lib/mysql # Requested, specifies the path to MySQL data persistent store.
networks:
- seafile-net
memcached:
image: memcached:1.6.18
entrypoint: memcached -m 256
networks:
- seafile-net
seafile:
- “80:80”
- “443:443” # If https is enabled, cancel the comment.
- /mnt/nfsprox/seafile-volume/seafile-data:/shared # Requested, specifies the path to Seafile data persistent store.
- DB_HOST=db
- DB_ROOT_PASSWD=OBSCURED # Requested, the value should be root's password of MySQL service.
- TIME_ZONE=Etc/UTC # Optional, default is UTC. Should be uncomment and set to your local time zone.
- SEAFILE_ADMIN_EMAIL=steve@example.com # Specifies Seafile admin user, default is 'me@example.com'.
- SEAFILE_ADMIN_PASSWORD=OBSCURED # Specifies Seafile admin password, default is 'asecret'.
- SEAFILE_SERVER_HOSTNAME=docs.seafile.com # Specifies your host name if https is enabled.
depends_on:
- db
- memcached
networks:
- seafile-net
networks:
seafile-net:
