When I try to download files from the web browser, it tries to download from https://files.******.net:8082/files/834a839e-67b6-4c78-b3fa-3057446ff68c/test.zip (port 8082).
If I manually change the URL to https://files.******.net/seafhttp/files/834a839e-67b6-4c78-b3fa-3057446ff68c/test.zip (default port + /seafhttp/) it downloads as expected.
Any ideas how I can configure Seafiles to provide the correct URL when using the web interface?
Wow I was in you very same situation and could’nt download anything from the browser (clients works fine). I couldn’t realize why, with your manual workaround at least I’m able to download files when needed.
Of course this is not the right behaviour. Could be something related with a wrong url passed from nginx to seafhttp. But I’m not sure how to fix, maybe somebody from Seafile can help us.
@92lleo You were correct. My FILE_SERVER_ROOT was missing. It was there before, but I probably accidentally replaced it when I copied someone else’s config to fix another problem. Now it works again and as a bonus my markdown previews also started to work.
