Download link for Seafile Pro edition
Hi all,
You can download Seafile Pro edition from here:
https://download.seafile.com/d/6e5297246c/?p=/pro&mode=list
Note, before downloading the program, please read the EULA first:
https://download.seafile.com/d/6e5297246c/files/?p=/pro/seafile_professional_edition_software_license_agreement.md
The software is free for 3 users.
Are these links final, can we trust them? I see this is a forum post which is not visible in the forum (you have to scroll to the very bottom and wait for javascript to create new entries to show it). I can’t find Pro download links anywhere else.
Also, is there a changelog for the Pro server? EDIT: Found the Pro changelog (should be added next to the Pro download link)
The download link is in this page too: https://www.seafile.com/en/product/private_server/
Where can I provide bug reports for the Pro Edition? Do you have Jira or would posting them on the forum do?
You could use GitHub?
You can report bugs for the Pro edition on Github too: https://github.com/haiwen/seafile
If you’re not sure whether it’s a bug or not, you should use the forum first.
I can’t download the Pro versions with wget, why’s that?
I want to download it to my ubuntu server directly with wget - is that possible?
Please use
wget “https://download.seafile.com/d/6e5297246c/files/?p=/pro/seafile-pro-server_6.1.9_x86-64.tar.gz&dl=1” -O seafile-pro-server_6.1.9_x86-64.tar.gz
Hi @daniel.pan @Jonathan where did the pro download directory move?
It is not accessible anymore via https://download.seafile.com/d/6e5297246c/?p=/pro&mode=list
Sorry It’s fixed now.
Hi @Jonathan @daniel.pan
I must be doing something really silly as it won’t donload the correct file with wget, instead of 140MB it downloads 6k?? What am I missing?
@Cisco, thank you so much, worked first time, obviously a syntax on my side
the website is down again. Could you have a look, please?
@Jonathan
The URL has been changed to SeafilePlus
You can also register our customer center and get the latest URL once it has been changed.
Lifesaver - I was going around and around in circles trying to find the Pro. My home Seafile lab is running on CentOS v7 which EOL so won’t update anymore. It’s running v10.x and I failed to get it any higher. Therefore, I’m going to try rebuilding the environment on a newer version of Linux and go through the upgrade process there - and then consider moving to a docker…
