So Here’s my setup.
I have Proxmox hosting a ubuntu 22.04 LXC (container) and ive installed Seafile on it. (i have another LXC that i run nginx proxy manager, to manage the SSL certs and a one stop shop in terms of setting up proxies).
The server (cloud[dot]mydomain[dot]pt) works great, ive uploaded / synced a lot of files to it from my main server and can download and upload at will. but ANYTHING above 1gb, ive hitting a wall where it just “stops”, no matter the browser. (ive made changes, as you’ll see in the files)
Heres my /opt/seafile/conf/seafile.conf , my /etc/nginx/sites-enabled/seafile.conf and my reverse proxy machine settings
log_format seafileformat '$http_x_forwarded_for $remote_addr [$time_local] "$request" $>
listen 80;
server_name seafile.example.com;
proxy_read_timeout 120000s;
add_header Cache-Control "no-cache";
proxy_connect_timeout 3600000s;
proxy_read_timeout 3600000s;
proxy_max_temp_file_size 0;
proxy_buffering off;
location /notification/ping {
proxy_pass http://127.0.0.1:8083/ping;
access_log /var/log/nginx/notification.access.log seafileformat;
error_log /var/log/nginx/notification.error.log;
location /notification {
proxy_pass http://127.0.0.1:8083/;
proxy_http_version 1.1;
location /seafdav {
proxy_pass http://127.0.0.1:8080/seafdav;
proxy_set_header Host $host;
access_log /var/log/nginx/seafdav.access.log seafileformat;
[fileserver]
port = 8082
max_download_dir_size = 2500000
[database]
type = mysql
host = 127.0.0.1
port = 3306
user = seafile
password = [REDACTED]
db_name = seafile_db
connection_charset = utf8
[notification]
enabled = false
host = 127.0.0.1
port = 8083
log_level = info
jwt_private_key = [REDACTED]
