When you edit a Markdown file on a web UI, the save and path bar is not displayed. Bug?
<div id="main" class="clear container-fluid ">
<div class="row">
<div id="main-panel" class="w100 ovhd">
<div id="path-op" class="ovhd">
<p class="path fleft">
Current path:
<a href="/#common/lib/ca45e512-9eec-4937-8c82-f55cd3ac10e9/">test2</a> /
<a href="/lib/ca45e512-9eec-4937-8c82-f55cd3ac10e9/file/test.md" target="_blank">test.md</a>
</p>
<div id="op-after-edit" class="fright vh">
<span id="saved-tip" class="tip hide">Draft saved.</span>
<button id="file-edit-submit">Submit</button>
<a href="/lib/ca45e512-9eec-4937-8c82-f55cd3ac10e9/file/test.md" id="file-edit-cancel">Cancel</a>
</div>
</div>
<div id="file-edit">
<div id="file-enc-cont">
<label for="file-enc">Encoding:</label>
<select id="file-enc">
<option value="auto" >auto detect</option>
<option value="utf-8" selected="selected" >utf-8</option>
<option value="gbk" >gbk</option>
<option value="ISO-8859-1" >ISO-8859-1</option>
<option value="ISO-8859-5" >ISO-8859-5</option>
</select>
</div>
