Hi christoph,
thanks, I performed almost all the steps you suggested. most of my python packages are installed by debian. so I did not upgrade those with pip (however I am sure it is not a problem of python, elasticsearch is java). I removed the whole elasticsearch search folder (although I tried that before). and cleared /tmp. and rebooted the machine.
The problem is still the same. elasticsearch refuses to start (bootstrap checks failed): here is the complete log of a elasticsearch startup:
[2019-09-03T13:56:53,109][INFO ][o.e.n.Node ] [] initializing …
[2019-09-03T13:56:53,371][INFO ][o.e.e.NodeEnvironment ] [oJ32maZ] using [1] data
paths, mounts [[/srv/seafile (/dev/mapper/melinda-seafile)]], net usable_space [20.
6gb], net total_space [22gb], spins? [possibly], types [btrfs]
[2019-09-03T13:56:53,372][INFO ][o.e.e.NodeEnvironment ] [oJ32maZ] heap size [100
7.3mb], compressed ordinary object pointers [true]
[2019-09-03T13:56:53,377][INFO ][o.e.n.Node ] node name [oJ32maZ] deri
ved from node ID [oJ32maZzSDKphL-09LG5Ug]; set [node.name] to override
[2019-09-03T13:56:53,378][INFO ][o.e.n.Node ] version[5.6.13], pid[374
1], build[4d5320b/2018-10-30T19:05:08.237Z], OS[Linux/3.16.0-10-amd64/amd64], JVM[Or
acle Corporation/OpenJDK 64-Bit Server VM/1.8.0_171/25.171-b11]
[2019-09-03T13:56:53,379][INFO ][o.e.n.Node ] JVM arguments [-Xms512m,
-Xmx1g, -XX:-AssumeMP, -XX:+UseConcMarkSweepGC, -XX:CMSInitiatingOccupancyFraction=
75, -XX:+UseCMSInitiatingOccupancyOnly, -XX:+AlwaysPreTouch, -Xss1m, -Djava.awt.head
less=true, -Dfile.encoding=UTF-8, -Djna.nosys=true, -Djdk.io.permissionsUseCanonical
Path=true, -Dio.netty.noUnsafe=true, -Dio.netty.noKeySetOptimization=true, -Dio.nett
y.recycler.maxCapacityPerThread=0, -Dlog4j.shutdownHookEnabled=false, -Dlog4j2.disable.jmx=true, -Dlog4j.skipJansi=true, -XX:+HeapDumpOnOutOfMemoryError, -Des.path.home=/srv/seafile/seafile-pro-server-7.0.8/pro/elasticsearch]
[2019-09-03T13:56:55,551][INFO ][o.e.p.PluginsService ] [oJ32maZ] loaded module [aggs-matrix-stats]
[2019-09-03T13:56:55,552][INFO ][o.e.p.PluginsService ] [oJ32maZ] loaded module [ingest-common]
[2019-09-03T13:56:55,553][INFO ][o.e.p.PluginsService ] [oJ32maZ] loaded module [lang-expression]
[2019-09-03T13:56:55,554][INFO ][o.e.p.PluginsService ] [oJ32maZ] loaded module [lang-groovy]
[2019-09-03T13:56:55,554][INFO ][o.e.p.PluginsService ] [oJ32maZ] loaded module [lang-mustache]
[2019-09-03T13:56:55,554][INFO ][o.e.p.PluginsService ] [oJ32maZ] loaded module [lang-painless]
[2019-09-03T13:56:55,555][INFO ][o.e.p.PluginsService ] [oJ32maZ] loaded module [parent-join]
[2019-09-03T13:56:55,555][INFO ][o.e.p.PluginsService ] [oJ32maZ] loaded module [percolator]
[2019-09-03T13:56:55,555][INFO ][o.e.p.PluginsService ] [oJ32maZ] loaded module [reindex]
[2019-09-03T13:56:55,556][INFO ][o.e.p.PluginsService ] [oJ32maZ] loaded module [transport-netty3]
[2019-09-03T13:56:55,556][INFO ][o.e.p.PluginsService ] [oJ32maZ] loaded module [transport-netty4]
[2019-09-03T13:56:55,557][INFO ][o.e.p.PluginsService ] [oJ32maZ] loaded plugin [analysis-ik]
[2019-09-03T13:57:00,219][INFO ][o.e.d.DiscoveryModule ] [oJ32maZ] using discovery type [zen]
[2019-09-03T13:57:01,581][INFO ][o.e.n.Node ] initialized
[2019-09-03T13:57:01,582][INFO ][o.e.n.Node ] [oJ32maZ] starting …
[2019-09-03T13:57:01,992][INFO ][o.e.t.TransportService ] [oJ32maZ] publish_address {130.60.155.220:9300}, bound_addresses {[::]:9300}
[2019-09-03T13:57:02,030][INFO ][o.e.b.BootstrapChecks ] [oJ32maZ] bound or publishing to a non-loopback address, enforcing bootstrap checks
[2019-09-03T13:57:02,040][ERROR][o.e.b.Bootstrap ] [oJ32maZ] node validation exception
[3] bootstrap checks failed
[1]: initial heap size [536870912] not equal to maximum heap size [1073741824]; this can cause resize pauses and prevents mlockall from locking the entire heap
[2]: max file descriptors [4096] for elasticsearch process is too low, increase to at least [65536]
[3]: max virtual memory areas vm.max_map_count [65530] is too low, increase to at least [262144]
[2019-09-03T13:57:02,057][INFO ][o.e.n.Node ] [oJ32maZ] stopping …
[2019-09-03T13:57:02,107][INFO ][o.e.n.Node ] [oJ32maZ] stopped
[2019-09-03T13:57:02,107][INFO ][o.e.n.Node ] [oJ32maZ] closing …
[2019-09-03T13:57:02,147][INFO ][o.e.n.Node ] [oJ32maZ] closed
according to the info I can find on the net (I have little knowledge of elasticsearch) the problem are the failed bootstrap checks.
so, the question here is, why is elasticsearch failing on my node. as far as I know, I did not touch the elasticsearch config. they are part of the seafile-server tar file, right?
Many thanks,
Hp
