Hi, I have already raised this issue on Github. Just posting here too for visibility since i didn’t get any response there.
We are facing an issue with connecting to Elasticsearch. Our ES cluster is currently using self-signed certificates to secure the connection via HTTPS. This causes issue when seafevents
tries to connect with below error:
06/16/2024 23:05:41 [ERROR] seafes:158 start_index_local: Index process init error: TLS error caused by: TlsError(TLS error caused by: SSLError([SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: self-signed certificate in certificate chain (_ssl.c:1007))).
I have tried using the below in seafevents.conf
but still getting the same error:
[INDEX FILES]
verify_certs = false
cafile = /shared/seafile/conf/es_cacert.pem
I am not sure if these are even used in the code. It should be a relatively easy fix to allow disabling cert verification and expose it as a config parameter.
Version details below:
Seafile version: 11.0.7 Pro (Docker - HA cluster)
Thanks!
