I can’t seem to open encrypted libraries in seahub (seafile web interface).
1 - Create the library with a password (either using seafile desktop client or seahub).
2 - Use a browser (private browsing for example)
3 - Login to Seafile in browser (this is called seahub right ?)
4 - Try to open an encrypted library with the password you’ve set
5 - Seahub says “wrong password”
I have had the case with v11.0.1 and v11.0.2.
I have tried passwords with @ and $, and then only upper and lower case letters.
Same result everytime.
I’m not sure how I would be the first one to discover this
. Must be something on my setup ?
EDIT :
So I’ve tried another thing :
- it still doesn’t work when I try from the browser
- but it does work when I try from seafile desktop app using “open cloud file explorer”.
- It then asks for the password, which I give, and it deems it correct.
After doing this, the real browser can open the encrypted library and doesn’t ask for password.
Moreover, deleting a library on seahub is refused, saying “permission denied”.
I’m beginning to wonder if it wouldn’t be something linked to LDAP accounts not having the same rights as classic seafile accounts. I’m currently using a ldap account.
