Hello!
I want to install Seafile in my VPS, and I was reading the documentation about Encrypted Library in Seafile. It say “The file encryption/decryption is performed on client-side when using the desktop client for file synchronization”. Is possible to use the Seafile CLI client to sync files to a Encrypted Library?
Thanks!
Juan
No, seafile cli works only with un-encrypted libraries. Same with Seafile FSCK “Currently only un-encrypted libraries can be exported. Encrypted libraries will be skipped.”
regards
Andreas
germeier@client:~$ lsb_release -d
Description: Ubuntu 22.04.1 LTS
germeier@client:~$ dpkg --list | grep seafile-cli
ii seafile-cli 8.0.7 amd64 Seafile command line interface.
germeier@client:~$ seaf-cli sync -help
usage: seaf-cli sync [-h] [-c CONFDIR] [-C C] [-l LIBRARY] [-s SERVER] [-u USERNAME] [-p PASSWORD] [-T TOKEN] [-a TFA] [-d FOLDER] [-e LIBPASSWD]
options:
-e LIBPASSWD, --libpasswd LIBPASSWD
library password
