Usually seafile fails to properly start on a system reboot. Most of the time I either re-start the stack and tell it to pull the containers, or manually access the console for the seafile container, cd to seafile-server-latest and then ./seahub.sh start
Today, none of that works.
Please understand “I don’t know what I don’t know” and if you need additional information please ask (And show how to provide) I am just some guy that started running this without fully understanding it.
Here is the information in the container logs (I assume thats the logs you need:
Error:Seahub failed to start.
File "/scripts/start.py", line 94, in <module>
main()
File "/scripts/start.py", line 80, in main
call('{} start'.format(get_script('seahub.sh')))
File "/scripts/utils.py", line 70, in call
File "/usr/lib/python3.10/subprocess.py", line 369, in check_call
subprocess.CalledProcessError: Command '/opt/seafile/seafile-server-11.0.13/seahub.sh start' returned non-zero exit status 1.
I get this unhelpful but when trying to run it in the container:
main()
Errors on the DB:
2025-10-16 21:40:12 0 [Note] InnoDB: Buffer pool(s) load completed at 251016 21:40:12
2025-10-16 21:40:17 6 [Warning] Aborted connection 6 to db: 'seahub_db' user: 'seafile' host: '172.18.0.4' (Got an error reading communication packets)
2025-10-16 21:42:33 4 [Warning] Aborted connection 4 to db: 'seafile_db' user: 'seafile' host: '172.18.0.4' (Got an error reading communication packets)
2025-10-16 21:42:33 5 [Warning] Aborted connection 5 to db: 'ccnet_db' user: 'seafile' host: '172.18.0.4' (Got an error reading communication packets)
2025-10-16 21:42:33 11 [Warning] Aborted connection 11 to db: 'seahub_db' user: 'seafile' host: '172.18.0.4' (Got an error reading communication packets)
2025-10-16 21:42:33 9 [Warning] Aborted connection 9 to db: 'seahub_db' user: 'seafile' host: '172.18.0.4' (Got an error reading communication packets)
2025-10-16 21:42:33 8 [Warning] Aborted connection 8 to db: 'seafile_db' user: 'seafile' host: '172.18.0.4' (Got an error reading communication packets)
2025-10-16 21:42:33 7 [Warning] Aborted connection 7 to db: 'seafile_db' user: 'seafile' host: '172.18.0.4' (Got an error reading communication packets)
2025-10-16 21:42:33 10 [Warning] Aborted connection 10 to db: 'seahub_db' user: 'seafile' host: '172.18.0.4' (Got an error reading communication packets)
2025-10-16 21:42:38 16 [Warning] Aborted connection 16 to db: 'seahub_db' user: 'seafile' host: '172.18.0.4' (Got an error reading communication packets)
And finally, at one point my stack in portaner was requested.. (Sensentive information removed)
db:
image: mariadb:10.11
container_name: seafile-mysql
- MYSQL_ROOT_PASSWORD= # Requested, set the root's password of MySQL service.
- MYSQL_LOG_CONSOLE=true
- MARIADB_AUTO_UPGRADE=1
- /poolof6s/MainFS/SubMain/config2/seafile:/var/lib/mysql # Requested, specifies the path to MySQL data persistent store.
networks:
- seafile-net
memcached:
image: memcached:1.6.18
entrypoint: memcached -m 256
networks:
- seafile-net
seafile:
- "8088:80"
# - "443:443" # If https is enabled, cancel the comment.
- /poolof6s/MainFS/SubMain/CustomerBackups/seafile:/shared # Requested, specifies the path to Seafile data persistent store.
- DB_HOST=db
- DB_ROOT_PASSWD= # Requested, the value should be root's password of MySQL service.
- TIME_ZONE=America/Toronto # Optional, default is UTC. Should be uncomment and set to your local time zone.
- SEAFILE_ADMIN_EMAIL= # Specifies Seafile admin user, default is 'me@example.com'.
- SEAFILE_ADMIN_PASSWORD= # Specifies Seafile admin password, default is 'asecret'.
- SEAFILE_SERVER_HOSTNAME=none.none.com # Specifies your host name if https is enabled.
depends_on:
- db
- memcached
networks:
- seafile-net
networks:
seafile-net:
Lil help? (Or if you need mroe info, feel free to ask, I will provide)
I also tried to look at the log in the container. Maybe I don’t know what log I need. but I deleted seahub.log (After backup) seahub was started from the console, and it re-created a 0 byte file. Did the same after starting the container again.
