I am running seafile 12.0.7 community edition in docker containers, and after a reboot I am running in to this error:
eafile | *** Running /etc/my_init.d/01_create_data_links.sh...
seafile | *** Booting runit daemon...
seafile | *** Runit started as PID 16
seafile | *** Running /scripts/enterpoint.sh...
seafile | 2025-03-12 20:30:33 Waiting Nginx
seafile | 2025-03-12 20:30:33 Nginx ready
seafile | 2025-03-12 20:30:33 This is an idle script (infinite loop) to keep container running.
seafile | [2025-03-12 20:30:33] Now running setup-seafile-mysql.py in auto mode.
seafile | Checking python on this machine ...
seafile |
seafile |
seafile | verifying password of user root ... done
seafile |
seafile | verifying password of user seafile ... done
seafile |
seafile | ---------------------------------
seafile | This is your configuration
seafile |
seafile | server name: seafile
seafile | server ip/domain: example.com
seafile |
seafile | seafile data dir: /opt/seafile/seafile-data
seafile | fileserver port: 8082
seafile |
seafile | database: create new
seafile | ccnet database: ccnet_db
seafile | seafile database: seafile_db
seafile | seahub database: seahub_db
seafile | database user: seafile
seafile |
seafile |
seafile | Generating seafile configuration ...
seafile |
seafile | done
seafile | Generating seahub configuration ...
seafile |
seafile | ----------------------------------------
seafile | Now creating seafevents database tables ...
seafile |
seafile | Now creating ccnet database tables ...
seafile |
seafile | Now creating seafile database tables ...
seafile |
seafile | Now creating seahub database tables ...
seafile |
seafile |
seafile | Error: Failed to init seahub database: Table 'abuse_reports_abusereport' already exists
seafile | File "/scripts/start.py", line 94, in <module>
seafile | main()
seafile | File "/scripts/start.py", line 59, in main
seafile | init_seafile_server()
seafile | File "/scripts/bootstrap.py", line 155, in init_seafile_server
seafile | call('{} auto -n seafile'.format(setup_script), env=env)
seafile | File "/scripts/utils.py", line 70, in call
seafile | return subprocess.check_call(*a, **kw)
seafile | ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
seafile | File "/usr/lib/python3.12/subprocess.py", line 413, in check_call
seafile | raise CalledProcessError(retcode, cmd)
seafile | subprocess.CalledProcessError: Command '/opt/seafile/seafile-server-12.0.7/setup-seafile-mysql.sh auto -n seafile' returned non-zero exit status 1.
I suspect the issue is with it trying to create a new database, as I am unsure why it would be doing this since setup has already been run before. I did make sure I am running the command in the director with the .env file, and the values in there have not changed.
Any guidance is appreciated.
