I have same issu with bytes-like object is required, not ‘str’
Could you please check my logs. I have no any ideas
docker-compose up
Removing seafile
seafile-memcached is up-to-date
seafile-mysql is up-to-date
Recreating f12edea1cc5a_seafile …
ERROR: for f12edea1cc5a_seafile a bytes-like object is required, not ‘str’
ERROR: for seafile a bytes-like object is required, not ‘str’
File “/usr/lib/python3/dist-packages/docker/api/client.py”, line 261, in _raise_for_status
response.raise_for_status()
File “/usr/lib/python3/dist-packages/requests/models.py”, line 940, in raise_for_status
raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 500 Server Error: Internal Server Error for url: http+docker://localhost/v1.22/containers/ee4c57f9c99361aeb95840fba88f35c6a4e57cdbb04a042db8d076776baa663e/start
File “/usr/lib/python3/dist-packages/compose/service.py”, line 625, in start_container
container.start()
File “/usr/lib/python3/dist-packages/compose/container.py”, line 241, in start
return self.client.start(self.id, **options)
File “/usr/lib/python3/dist-packages/docker/utils/decorators.py”, line 19, in wrapped
return f(self, resource_id, *args, **kwargs)
File “/usr/lib/python3/dist-packages/docker/api/container.py”, line 1095, in start
self._raise_for_status(res)
File “/usr/lib/python3/dist-packages/docker/api/client.py”, line 263, in _raise_for_status
raise create_api_error_from_http_exception(e)
File “/usr/lib/python3/dist-packages/docker/errors.py”, line 31, in create_api_error_from_http_exception
raise cls(e, response=response, explanation=explanation)
docker.errors.APIError: 500 Server Error: Internal Server Error (“b’driver failed programming external connectivity on endpoint seafile (adafaba3a31835096df1802ae9629a80e4c72158f55d89c61f3f8f5d5b21d4fa): Bind for 0.0.0.0:443 failed: port is already allocated’”)
File “/usr/bin/docker-compose”, line 11, in
load_entry_point(‘docker-compose==1.25.0’, ‘console_scripts’, ‘docker-compose’)()
File “/usr/lib/python3/dist-packages/compose/cli/main.py”, line 72, in main
command()
File “/usr/lib/python3/dist-packages/compose/cli/main.py”, line 128, in perform_command
handler(command, command_options)
File “/usr/lib/python3/dist-packages/compose/cli/main.py”, line 1107, in up
to_attach = up(False)
File “/usr/lib/python3/dist-packages/compose/cli/main.py”, line 1088, in up
return self.project.up(
File “/usr/lib/python3/dist-packages/compose/project.py”, line 565, in up
results, errors = parallel.parallel_execute(
File “/usr/lib/python3/dist-packages/compose/parallel.py”, line 112, in parallel_execute
raise error_to_reraise
File “/usr/lib/python3/dist-packages/compose/parallel.py”, line 210, in producer
result = func(obj)
File “/usr/lib/python3/dist-packages/compose/project.py”, line 548, in do
return service.execute_convergence_plan(
File “/usr/lib/python3/dist-packages/compose/service.py”, line 561, in execute_convergence_plan
return self._execute_convergence_recreate(
File “/usr/lib/python3/dist-packages/compose/service.py”, line 486, in _execute_convergence_recreate
containers, errors = parallel_execute(
result = func(obj)
File “/usr/lib/python3/dist-packages/compose/service.py”, line 481, in recreate
return self.recreate_container(
File “/usr/lib/python3/dist-packages/compose/service.py”, line 602, in recreate_container
self.start_container(new_container)
File “/usr/lib/python3/dist-packages/compose/service.py”, line 627, in start_container
if “driver failed programming external connectivity” in ex.explanation:
TypeError: a bytes-like object is required, not ‘str’
