I’m using self hosted server v7.1.5 on ubuntu and seadrive client v2.0.12 on windows, both fresh install, I’m getting an “Failed to index file …” error everytime i try to upload large file, not sure where is exact limit but generally 500MB+, thing is the file gets uploaded successfully, file intergrity is 100% correct, so in the end everything works, but I just feel bad because of that error message.
Can anyone give me some hints, where to go, what to check, how to fix that ?
seadrive.log looks like this:
[05/05/21 03:28:09] CDC: failed to open C:\seadrive\user/My Libraries/backup/zalohy/zfile.AVI.
[05/05/21 03:28:09] Failed to chunk file with CDC.
[05/05/21 03:28:09] Failed to index file C:\seadrive\user/My Libraries/backup/zalohy/zfile.AVI
[05/05/21 03:28:09] All events are processed for repo ad594476-8be8-4c07-9516-72f3b1227b2d.
[05/05/21 03:28:09] Repo ‘backup’ sync state transition from ‘committing’ to ‘uploading’.
[05/05/21 03:28:09] Upload with HTTP sync protocol version 2.
[05/05/21 03:28:09] Transfer repo ‘ad594476’: (‘normal’, ‘init’) --> (‘normal’, ‘check’)
[05/05/21 03:28:09] Transfer repo ‘ad594476’: (‘normal’, ‘check’) --> (‘normal’, ‘commit’)
[05/05/21 03:28:09] Transfer repo ‘ad594476’: (‘normal’, ‘commit’) --> (‘normal’, ‘fs’)
[05/05/21 03:28:09] Transfer repo ‘ad594476’: (‘normal’, ‘fs’) --> (‘normal’, ‘data’)
[05/05/21 03:28:09] Transfer repo ‘ad594476’: (‘normal’, ‘data’) --> (‘normal’, ‘update-branch’)
[05/05/21 03:28:09] Transfer repo ‘ad594476’: (‘normal’, ‘update-branch’) --> (‘finished’, ‘finished’)
[05/05/21 03:28:09] removing blocks for repo ad594476-8be8-4c07-9516-72f3b1227b2d
[05/05/21 03:28:09] Repo ‘backup’ sync state transition from ‘uploading’ to ‘get sync info’.
[05/05/21 03:28:09] Repo ‘backup’ sync state transition from ‘get sync info’ to ‘synchronized’.
[05/05/21 03:28:11] Repo ‘backup’ sync state transition from ‘synchronized’ to ‘committing’.
[05/05/21 03:28:11] CDC: failed to open C:\seadrive\user/My Libraries/backup/zalohy/zfile.AVI.
[05/05/21 03:28:11] Failed to chunk file with CDC.
[05/05/21 03:28:11] Failed to index file C:\seadrive\user/My Libraries/backup/zalohy/zfile.AVI
[05/05/21 03:28:11] All events are processed for repo ad594476-8be8-4c07-9516-72f3b1227b2d.
[05/05/21 03:28:11] Repo ‘backup’ sync state transition from ‘committing’ to ‘synchronized’.
[05/05/21 03:28:18] Repo ‘backup’ sync state transition from ‘synchronized’ to ‘committing’.
[05/05/21 03:28:25] Creating partial commit after adding zfile.AVI in repo backup(ad594476).
The failure occur two times in log, but only once in synchonization error list.
There is one more failure bit earlier:
[05/05/21 03:27:45] Failed to open file C:\seadrive\user/My Libraries/backup/zalohy: 5
[05/05/21 03:27:45] Bad response code for POST example. com/api/v2.1/copy-move-task/: 400.
Thanks
Edit: I updated server to 8.0.4 and seadrive to 2.0.13, problem still persist
