My library stuck here. I’ve reinstalled seadrive already and checked the lib with seaf-fsck.sh on server. No luck. I’m on Ubuntu 18 with latest seadrive cli.
[10/28/18 16:57:06] http-tx-mgr.c(3919): Upload with HTTP sync protocol version 2.
[10/28/18 16:57:06] http-tx-mgr.c(1186): Transfer repo '512ff274': ('normal', 'init') --> ('normal', 'check')
[10/28/18 16:57:07] http-tx-mgr.c(1186): Transfer repo '512ff274': ('normal', 'check') --> ('normal', 'commit')
[10/28/18 16:57:07] http-tx-mgr.c(1186): Transfer repo '512ff274': ('normal', 'commit') --> ('normal', 'fs')
[10/28/18 16:57:07] http-tx-mgr.c(1186): Transfer repo '512ff274': ('normal', 'fs') --> ('normal', 'data')
[10/28/18 16:57:07] fs-mgr.c(591): [fs mgr] Failed to read file 545cdfed8f33424b1de4b257f4c2ca74042e6bc6.
[10/28/18 16:57:07] http-tx-mgr.c(3655): Failed to get file 545cdfed8f33424b1de4b257f4c2ca74042e6bc6 in repo 512ff274.
[10/28/18 16:57:08] http-tx-mgr.c(911): libcurl failed to PUT https://hostname/seafhttp/repo/512ff274-786a-4755-ab00-adef6a4371ea/block/a757c857403fc6bbca10f604a68e6928edf426b4: Operation was aborted by an application callback.
[10/28/18 16:57:08] http-tx-mgr.c(1186): Transfer repo '512ff274': ('normal', 'data') --> ('error', 'finished')
[10/28/18 16:57:08] sync-mgr.c(604): Repo 'pdf-files' sync state transition from uploading to 'error': 'Error occured in upload.'.
[10/28/18 16:57:37] sync-mgr.c(570): Repo 'pdf-files' sync state transition from 'synchronized' to 'uploading'.
[10/28/18 16:57:37] http-tx-mgr.c(3919): Upload with HTTP sync protocol version 2.
[10/28/18 16:57:37] http-tx-mgr.c(1186): Transfer repo '512ff274': ('normal', 'init') --> ('normal', 'check')
[10/28/18 16:57:38] http-tx-mgr.c(1186): Transfer repo '512ff274': ('normal', 'check') --> ('normal', 'commit')
[10/28/18 16:57:38] http-tx-mgr.c(1186): Transfer repo '512ff274': ('normal', 'commit') --> ('normal', 'fs')
[10/28/18 16:57:38] http-tx-mgr.c(1186): Transfer repo '512ff274': ('normal', 'fs') --> ('normal', 'data')
[10/28/18 16:57:38] fs-mgr.c(591): [fs mgr] Failed to read file 545cdfed8f33424b1de4b257f4c2ca74042e6bc6.
[10/28/18 16:57:38] http-tx-mgr.c(3655): Failed to get file 545cdfed8f33424b1de4b257f4c2ca74042e6bc6 in repo 512ff274.
[10/28/18 16:57:38] http-tx-mgr.c(1186): Transfer repo '512ff274': ('normal', 'data') --> ('error', 'finished')
[10/28/18 16:57:38] sync-mgr.c(604): Repo 'pdf-files' sync state transition from uploading to 'error': 'Error occured in upload.'.
Nginx access log gives this
[28/Oct/2018:17:29:41 +0000] "PUT /seafhttp/repo/512ff274-786a-4755-ab00-adef6a4371ea/block/a757c857403fc6bbca10f604a68e6928edf426b4 HTTP/1.1" 400 0 "-" "Seafile/0.9.5 (Linux)"
